1 - 3 of 3 Posts
hi guys, i am going to install the 13" stoptech front bbk only, do i have to do anything to the rear to balance the brake system or is it fine just installing the front bbk and leave the rear as it is?? when i searched, i found sth called proportioning valve, what is that also?? thanks :thanks:
to balance, just go to a slightly more aggressive compound in the rear
UUC has a section about this on their site (in the BBK section) if you want to know more. You do not need an (adjustible) proportioning valve. It is a device used primarily in race cars to change front/rear brake balance on the fly to compensate for changing conditions. You would spend a ton of time trying to integrate this into your stock system (god knows how it would work with ABS and DSC) for a result that is completely unnecessary on a street driven car. Hope this helps. :thumbup:
My understanding is that the brake system (i.e., master cylinder, etc) is already set for this and you should have to change anything - the difference shouldnt be a major issue since the brake bias must be toward the front first and foremost. Who did you buy the stoptechs from - definitely call that person to ask.
1 - 3 of 3 Posts
