1 - 8 of 8 Posts
Okay ive done TONS of searching and i purposely did not post this in the ///M section because i need all the help i can...
Okay so- rained .. My eagle eye tail lights did not seal all the way allowing water to leak in the right side
Blew some fuses
Burned out my corner light socket and right taillight (all replaced)
Replaced fuses fixed all things
Before my steering wheels controls did not work and all kinds of random stuff... (vanity r/s light ect.)
Now everythings fixed
Even checked for infamous tailight ground failure - nothing :(
Checked for bad connections anything
Ive literally been trying for 3 months car has been sitting!
Everything works execpt the following:
- the dsc does not react
-hk button does not react
-Sport button reacts but no
illumination
Tire pressure button works fine!
WTF!? Ive tried it all... Cleaned speed sensors everything!!
Anyone has an idea or gone theu this before?
Car works 100% everything
No codes just ZKE MODULE for interior light fail whitch i have no idea why
Its annoying to have an M3 and stuck with DSC on ***128529;***128529;
Feel like no one would even buy it now smh PLEASE HELP!!!
2002 M3
No heated seats
Oem nav
No check engine
No error codes ...
Discussion Starter #2
And just to make it clear for ppl that dont know what ON means ..
-No the DSC warning light is not ON
-No the Brake light is not ON
Still flashes and engages wen trying to spin, chirp, ect...
it sounds like the button box is broken in some way. can you get a used one with the same buttons from a part out in the classifieds?
Discussion Starter #4
I found one on ebay for 80$ just dont want to waste my money/time if thats not the problem
Saw on a euro forum today someone had mentioned the steering possition sensor? Would not engage DSC?
You said your DSC is working properly, it just won't turn off with the button. You also said your HK Audio button doesn't do anything. Why the **** would that lead you to the steering angle sensor? Think logically...
Check all fuses again. If they're all good then replace the button panel.
Discussion Starter #7
Just changed my center console switch and still have the exact same issue ***128553;
1 - 8 of 8 Posts
