got the LED retrofit...
thanks, but not that one...on the trunk deck...the reverse light lenses...menace3054 said:
I think it is fairly easy, but I think you will have to take off the trunkliner...e_one09 said:I would want to know too.
Thanks!krispykreme said:it's very easy.
Open the trunck lid. At the bottom of trunk lid, there are two black circular clips. Remove those. Ther are two more clips on the inside of trunk lid, in a dip above the trunk lights. Remove those two.
You should be able to bent the interior trim down and expose the light assembly. Unplug the connectors that into the trunk lens. Each light is hold in place by a white clip. At bottom of each white clip is a screw. Loosen the screw all the way down and pop the light out.
To install the light make sure that the clips on the side of lens fits with the trunk and the white clips contact the trunk lid (not the lense) when install the light back in place.
