81 - 100 of 723 Posts
Latest versions for your car:
DME: 7571604
EGS: 7558410
Thanks Bali,
Now if someone can do this for me? :eeps: Got quoted $155 from a local dealership, said it covers both DME and EGS.
if you do a manual flash (Choose ZUSB) how would one know whats the latest version for their dme? or whats the best way to check?
# USER INFO FIELDS
Unit Date VIN Odometer Assembly Software Service Dealer Tester Program ver.
DME* -> 17.11.03 7.540.380 7.540.381 0.000.000 012321 42324 0044570LL00S
edit: all good.
Hi Bali,
I have a question about the k+dcan cable does pin 7 & 8 have to be bridged to do up date/flash on a E46? I bought the cable and software of ebay. It was one click install (Inpa 5.0.6, Winkfp 5.3.1, Integrated sp daten v53.3, some other bmw tools). Are there specific E46 files needed import/export to winkfp before flashing? If you have the time can you pls check if there are updates for DME and EGS. I have 2003 325i auto. Car not running smooth esp trans when cold 3rd to 2nd is rough in manual mode. Thanks in advance
# USER INFO FIELDS
DME -> 25.10.02 WBAEV33453KL81907 0 km 7.525.331 7.525.332 0.000.000 012321 42324 -
EGS -> 25.10.02 WBAEV33453KL81907 0 km 7.528.454 7.528.455 0.000.000 012321 42324 -
Administrator
2004 330Ci 115k miles
Discussion Starter · #84 ·
Yes, solder pins 7 and 8 together on the circuit board inside the OBD connector.
The E46 daten files need to be imported into WinKFP if the install didn't already do it.
DME -> 7525331
EGS -> 7528454
DME update: 7571608
http://www.realoem.com/bmw/enUS/showparts?id=ET37-USA-10-2002-E46-BMW-325i&diagId=12_1080
EGS update: 7558388
http://www.realoem.com/bmw/enUS/showparts?id=ET37-USA-10-2002-E46-BMW-325i&diagId=24_0886
I included the links to look up the latest versions on realoem.com. I probably should have already mentioned that this is an easy way to check for the latest versions.
Administrator
Discussion Starter · #85 ·
EGS version history (GD20.HIS)
;Zusbauhistorie vom 21.06.2006 10:34
;SG-TYP: GD20
;ZB-ALT ZB-NEU FREIKENNUNG
4511032,4511107,00,29
4511030,4511105,00,29
4511044,4511109,00,29
4511105,1423496,00,29
4511109,1423494,00,29
4511107,1423498,00,29
1423494,1423552,00,29
1423498,1423556,00,29
1423503,1423554,00,29
1423496,1423550,00,29
4511147,1423614,00,29
1423552,1423670,00,29
1423556,1423668,00,29
1423614,1423769,00,29
1423670,1423779,00,29
1423550,1423777,00,29
1423668,1423775,00,29
1423554,1423773,00,29
1423769,1423809,00,29
1423771,1423811,00,29
1423773,1423913,00,29
1423775,1423915,00,29
1423777,1423919,00,29
1423779,1423921,00,29
1423960,7504205,00,29
7503368,7504207,00,29
1423980,7504210,00,29
1423965,7504212,00,29
1423969,7504214,00,29
1423967,7504216,00,29
1423978,7504221,00,29
1423962,7504218,00,29
7503841,7504681,00,29
7504214,7504683,00,29
7504216,7504685,00,29
7504212,7504687,00,29
7504210,7504689,00,29
7504221,7504691,00,29
7504205,7504693,00,29
7504207,7504695,00,29
7504681,7504779,00,29
7504693,7505976,00,29
7504689,7506060,00,29
7504687,7506058,00,29
7504685,7506056,00,29
7504683,7506054,00,29
7506048,7506311,00,29
7506052,7506309,00,29
4455042,4457393,00,29
4455043,4457395,00,29
7505976,7507710,00,29
7505019,7507718,00,29
7504218,7508684,00,29
7506859,7508686,00,29
7507592,7506685,00,29
7507590,7508414,00,29
7507588,7508412,00,29
7508684,7509268,00,29
7507287,7509137,00,29
7508382,7509348,00,29
7508384,7509350,00,29
7509137,7509936,00,29
7508477,7510007,00,29
7508416,7510005,00,29
7509268,7507712,00,29
7504691,7509517,00,29
7507392,7510136,00,29
7507396,7510138,00,29
7507394,7510130,00,29
7507759,7510140,00,29
7507689,7510132,00,29
7507761,7510142,00,29
7509348,7510134,00,29
7509350,7510144,00,29
7508110,7510284,00,29
7509936,7511153,00,29
7508380,7511194,00,29
7508378,7511196,00,29
4460983,7511504,00,29
7507691,7511198,00,29
7507763,7511377,00,29
7511194,7511373,00,29
7511196,7511375,00,29
7511502,7511970,00,29
7508686,7511930,00,29
7508412,7511214,00,29
7508414,7511218,00,29
7511379,7507714,00,29
7510132,7511963,00,29
7511198,7512089,00,29
7510134,7512085,00,29
7510130,7512086,00,29
7511375,7512087,00,29
7511373,7512088,00,29
7507687,7512165,00,29
7510140,7513273,00,29
7510142,7513384,00,29
7511963,7513386,00,29
7512088,7513388,00,29
7510136,7513390,00,29
7512086,7513392,00,29
7510138,7513394,00,29
7510144,7513396,00,29
7512085,7513398,00,29
7511970,7513524,00,29
7510284,7513526,00,29
7512165,7513816,00,29
7511504,7513822,00,29
7511930,7513820,00,29
7512087,7513812,00,29
7511153,7513818,00,29
7511377,7513522,00,29
7507714,7513810,00,29
7512089,7513814,00,29
4461871,7514054,00,29
7511214,7514050,00,29
7511218,7514052,00,29
7510005,7514075,00,29
7510007,7514077,00,29
7510146,7514073,00,29
7514054,7515405,00,29
4462943,4465140,00,29
7513528,7515752,00,29
7515407,7516817,00,29
7513820,7518823,00,29
7513526,7519165,00,29
7512855,7519167,00,29
7515752,7519169,00,29
7516192,7518312,00,29
7516184,7518163,00,29
7516817,7518165,00,29
7518163,7519737,00,29
7518165,7519735,00,29
7513524,7512855,00,29
7515405,7518161,01,29
7518137,7521800,00,29
7518159,7521801,00,29
7518141,7521802,00,29
7518139,7521803,00,29
7518155,7521804,00,29
7518157,7521805,00,29
7518149,7521806,00,29
7518151,7521807,00,29
7518147,7521808,00,29
7518135,7521809,00,29
7518490,7521810,00,29
7518492,7521811,00,29
7518145,7521812,00,29
7518161,7521813,00,29
7518312,7521814,00,29
7519737,7521815,00,29
7519735,7521816,00,29
7520720,7521817,00,29
7518306,7521818,00,29
7518308,7521819,00,29
7519299,7521820,00,29
7519301,7521821,00,29
7518153,7521822,00,29
7518143,7521823,00,29
7518310,7521824,00,29
7521815,7522211,00,29
7521816,7522216,00,29
7521817,7523125,00,29
7518484,7523101,00,29
7523125,7523284,00,29
4471612,7525226,00,29
4471614,7525228,00,29
4471608,7525230,00,29
4471632,7525232,00,29
4471634,7525234,00,29
4471636,7525236,00,29
4471618,7525238,00,29
4471620,7525240,00,29
4471622,7525242,00,29
4471616,7525244,00,29
4471610,7525246,00,29
4471624,7525248,00,29
4471626,7525250,00,29
4471628,7525252,00,29
4471630,7525254,00,29
7525254,7526450,00,29
7525250,7526487,00,29
7525252,7526489,00,29
7525244,7526460,00,29
7525242,7526458,00,29
7525238,7526454,00,29
7525240,7526452,00,29
7525246,7526462,00,29
7525236,7527104,00,29
7525234,7527106,00,29
7525232,7527276,00,29
7526450,7528134,00,29
7526460,7528448,00,29
7526458,7528450,00,29
7528134,7528452,00,29
7527276,7528454,00,29
7527104,7528456,00,29
7526462,7528842,00,29
7526454,7528844,00,29
7526452,7528846,00,29
7526487,7528848,00,29
7526489,7528850,00,29
7526456,7528852,00,29
7525248,7528854,00,29
7527106,7528856,00,29
7527304,7530016,00,29
7527302,7530018,00,29
7527306,7530020,00,29
7527372,7530026,00,29
7527374,7530028,00,29
7530016,7531638,00,29
7530020,7531732,00,29
7530018,7531730,00,29
7530026,7531748,00,29
7530028,7531750,00,29
7530524,7531762,00,29
7530526,7531764,00,29
7530520,7531758,00,29
7530522,7531760,00,29
7530530,7531766,00,29
7525226,7532298,00,29
7525228,7532300,00,29
7525230,7532302,00,29
7528844,7532320,00,29
7528450,7532322,00,29
7528846,7532324,00,29
7528856,7532326,00,29
7528456,7532328,00,29
7528852,7532330,00,29
7528854,7532332,00,29
7528848,7532334,00,29
7528850,7532336,00,29
7531752,7533786,00,29
7531754,7533788,00,29
7531738,7533764,00,29
7531740,7533766,00,29
7531742,7533768,00,29
7531744,7533770,00,29
7531746,7533772,00,29
7532550,7533774,00,29
7532552,7533776,00,29
7532554,7533778,00,29
7532556,7533780,00,29
7532558,7533782,00,29
7531758,7533744,00,29
7531760,7533746,00,29
7531734,7533758,00,29
7531736,7533760,00,29
7531764,7533750,00,29
7531762,7533748,00,29
7533746,7535028,00,29
7533744,7535026,00,29
7531766,7533752,00,29
7533764,7535060,00,29
7533786,7535034,00,29
7533788,7535036,00,29
7533768,7535062,00,29
7533772,7537254,00,29
7535026,7537456,00,29
7535028,7537454,00,29
7533770,7537462,00,29
7533748,7539254,00,29
7533750,7539256,00,29
7533752,7539258,00,29
7533758,7540444,00,29
7533760,7540446,00,29
7536684,7540804,00,29
7536688,7540808,00,29
7536686,7540806,00,29
7537456,7542028,00,29
7539258,7542032,00,29
7537454,7542030,00,29
7539254,7542034,00,29
7539256,7542036,00,29
7540444,7542038,00,29
7540446,7542040,00,29
7521810,7526448,00,29
7521811,7526441,00,29
7526448,7532306,00,29
7526441,7532308,00,29
7521818,7532310,00,29
7521819,7532312,00,29
7532314,7542338,00,29
7528818,7542324,00,29
7532312,7542326,00,29
7528822,7542332,00,29
7532308,7542334,00,29
7528820,7542328,00,29
7532306,7542330,00,29
7537458,7543276,00,29
7537254,7543270,00,29
7537462,7543280,00,29
7537464,7543272,00,29
7537460,7543278,00,29
7537466,7543274,00,29
7535034,7543042,00,29
7535036,7543044,00,29
7533766,7543046,00,29
7535062,7543048,00,29
7535060,7543050,00,29
7533774,7543052,00,29
7533776,7543054,00,29
7533778,7543056,00,29
7533780,7543058,00,29
7533782,7543060,00,29
7542038,7543038,00,29
7542040,7543040,00,29
7542028,7543066,00,29
7542030,7543068,00,29
7542032,7543070,00,29
7542034,7543072,00,29
7542036,7543074,00,29
7540804,7545912,00,29
7540806,7545914,00,29
7540808,7545916,00,29
7528454,7532304,00,29
7528842,7532338,00,29
7528448,7532340,00,29
7543066,7547570,00,29
7543068,7547572,00,29
7518486,7548682,00,29
7543064,7549180,00,29
7543272,7549472,00,29
7543276,7549474,00,29
7550834,7552956,00,29
7550836,7552958,00,29
7550838,7552960,00,29
7550840,7552962,00,29
7550842,7552964,00,29
7550844,7552966,00,29
7550846,7552968,00,29
7509517,7552706,00,29
7507712,7552708,00,29
7513396,7552710,00,29
7513398,7552712,00,29
7518821,7552714,00,29
7519165,7552716,00,29
7519167,7552718,00,29
7518823,7552720,00,29
7513818,7552722,00,29
7522211,7552724,00,29
7522216,7552726,00,29
7521822,7553158,00,29
7521823,7553160,00,29
7527294,7553162,00,29
7552956,7557000,00,29
7552958,7557002,00,29
7521824,7532314,00,29
7521814,7532316,00,29
7528452,7537464,00,29
7531728,7537466,00,29
7531638,7537458,00,29
7531726,7537460,00,29
7549456,7543062,00,29
7549458,7543064,00,29
7543062,7549178,00,29
7543274,7549452,00,29
7543278,7549454,00,29
7543270,7549456,00,29
7543280,7549458,00,29
7547572,7557472,00,29
7543074,7557510,00,29
7552964,7557490,00,29
7552968,7557492,00,29
7552960,7557494,00,29
7552966,7557496,00,29
7552962,7557498,00,29
7543040,7557500,00,29
7543046,7557502,00,29
7543050,7557504,00,29
7543054,7557506,00,29
7543060,7557508,00,29
7543038,7557978,00,29
7557500,7557980,00,29
7547570,7557988,00,29
7543072,7558004,00,29
7543070,7558028,00,29
7557472,7557990,00,29
7557510,7558006,00,29
7552630,7558034,00,29
7543052,7557982,00,29
7543056,7557986,00,29
7543048,7557994,00,29
7543058,7558000,00,29
7549178,7558020,00,29
7549180,7558022,00,29
7543042,7558024,00,29
7543044,7558026,00,29
7557506,7557984,00,29
7557502,7557992,00,29
7557490,7557996,00,29
7557492,7557998,00,29
7557508,7558002,00,29
7557504,7558008,00,29
7557494,7558010,00,29
7557496,7558012,00,29
7557498,7558014,00,29
7557000,7558016,00,29
7557002,7558018,00,29
7552626,7558030,00,29
7552628,7558032,00,29
7519169,7549462,00,29
7532340,7558402,00,29
7531732,7558404,00,29
7531730,7558406,00,29
7532322,7558408,00,29
7532328,7558410,00,29
7532304,7558388,00,29
7558020,7563638,00,29
7558022,7563640,00,29
7558024,7563642,00,29
7558026,7563644,00,29
7558030,7563648,00,29
7558032,7563650,00,29
7558028,7563646,00,29
7558034,7563652,00,29
Administrator
Discussion Starter · #86 ·
MS43 version history (MDS43.HIS)
;Zusbauhistorie vom 09.07.2007 10:30
;SG-TYP: MDS43
4455163,4457156,00,19
4455161,4457093,00,19
4456244,4457312,00,19
4456242,4457314,00,19
4456831,4457788,00,19
4456837,4457782,00,19
4457314,4457780,00,19
4456833,4457784,00,19
4457312,4457774,00,19
4456835,4457768,00,19
4456646,4457766,00,19
4457156,7507814,00,19
4457093,7507816,00,19
4457680,4458527,00,19
4457678,4458527,00,19
4457788,4458525,00,19
4457786,4458523,00,19
4457790,4458521,00,19
4457784,4458521,00,19
4457782,4458519,00,19
4457780,4458517,00,19
4457778,4458515,00,19
4457776,4458513,00,19
4457774,4458511,00,19
4457772,4458509,00,19
4457770,4458506,00,19
4457768,4458504,00,19
4457766,4458502,00,19
7507816,7508284,00,19
7507814,7508283,00,19
7507534,7508282,00,19
7507536,7508281,00,19
4457682,4458764,00,19
4457804,4458766,00,19
4457810,4458768,00,19
4457806,4458770,00,19
4457816,4458772,00,19
4457808,4458774,00,19
4457818,4458838,00,19
4457814,4458840,00,19
4457812,4458842,00,19
4457684,4458776,00,19
4457686,4458778,00,19
4457792,4458780,00,19
4457802,4458782,00,19
4457954,4458784,00,19
4457956,4458786,00,19
4457794,4458788,00,19
4457796,4458790,00,19
4457800,4458792,00,19
4457798,4458836,00,19
7508281,7508423,00,19
7508282,7508424,00,19
7508283,7508425,00,19
7508284,7508426,00,19
7508423,7508868,00,19
7508424,7508869,00,19
7508425,7508870,00,19
7508426,7508871,00,19
7509590,7510201,00,19
7509588,7510199,00,19
7509586,7510197,00,19
7509876,7510195,00,19
7509874,7509653,00,19
7509866,7509422,00,19
7509860,7510113,00,19
7509858,7510103,00,19
7509663,7509922,00,19
7509846,7509906,00,19
7509584,7509888,00,19
7509582,7509886,00,19
7509580,7509880,00,19
7509934,7510245,00,19
7509928,7510243,00,19
7509926,7510241,00,19
7509924,7510239,00,19
7509916,7510237,00,19
7509606,7510235,00,19
7509914,7510233,00,19
7509910,7510231,00,19
7509657,7510229,00,19
7509908,7510227,00,19
7509904,7510225,00,19
7509604,7510223,00,19
7509420,7510358,00,19
7509457,7510600,00,19
7509455,7510209,00,19
7509667,7510580,00,19
7509576,7510572,00,19
7509669,7510578,00,19
7509834,7510586,00,19
7509649,7510576,00,19
7509570,7510565,00,19
7509661,7510584,00,19
7509578,7510574,00,19
7509647,7510203,00,19
7509653,7510499,00,19
7509422,7510497,00,19
7510199,7510505,00,19
7510113,7510495,00,19
7510197,7510503,00,19
7510201,7510507,00,19
7510195,7510501,00,19
7509608,7509872,00,19
7509862,7510588,00,19
7509572,7510567,00,19
7509665,7510582,00,19
7509894,7510590,00,19
7509574,7510570,00,19
7509645,7509900,00,19
7510103,7510493,00,19
7509886,7510485,00,19
7509922,7510491,00,19
7509906,7510489,00,19
7509880,7509428,00,19
7509888,7510487,00,19
7509453,7510612,00,19
7509451,7510610,00,19
7509461,7510614,00,19
7510312,7510481,00,19
7509426,7509459,00,19
7510150,7510479,00,19
7509447,7509411,00,19
7509399,7510539,00,19
7509393,7510533,00,19
7509443,7510557,00,19
7509395,7510535,00,19
7509445,7510559,00,19
7509397,7510537,00,19
7509932,7509842,00,19
7509930,7509840,00,19
7509938,7509838,00,19
7509912,7509659,00,19
7509898,7509844,00,19
7509413,7510551,00,19
7509409,7510549,00,19
7509439,7509864,00,19
7509437,7509856,00,19
7509433,7509852,00,19
7509431,7509850,00,19
7509449,7509870,00,19
7509441,7509854,00,19
7509435,7509854,00,19
7509902,7510608,00,19
7509892,7510606,00,19
7509675,7510604,00,19
7509671,7510602,00,19
7509602,7510598,00,19
7509600,7510596,00,19
7509598,7510594,00,19
7509896,7510592,00,19
7510245,7510531,00,19
7510243,7510529,00,19
7510241,7510527,00,19
7510239,7510525,00,19
7510237,7510523,00,19
7510235,7510521,00,19
7510233,7510519,00,19
7510231,7510517,00,19
7510229,7510515,00,19
7510227,7510513,00,19
7510225,7510511,00,19
7510223,7510509,00,19
7509848,7510221,00,19
7509836,7510219,00,19
7509890,7510217,00,19
7509884,7510215,00,19
7509882,7510213,00,19
7509878,7510211,00,19
7509594,7510207,00,19
7509592,7510205,00,19
7509401,7511437,00,19
7509403,7511438,00,19
7509405,7511439,00,19
7509407,7511440,00,19
7509415,7511441,00,19
7509418,7511442,00,19
7509424,7511443,00,19
7510152,7511444,00,19
7510610,7509651,00,19
7510612,7509868,00,19
7510614,7510483,00,19
7510479,7511355,00,19
7510481,7511357,00,19
7509411,7511359,00,19
7510358,7511361,00,19
7509459,7511363,00,19
7510537,7511467,00,19
7510559,7511469,00,19
7510535,7511471,00,19
7509870,7510148,00,19
7510557,7511883,00,19
7509864,7511631,00,19
7509856,7511633,00,19
7509854,7511635,00,19
7509852,7511637,00,19
7509850,7511869,00,19
7509844,7511871,00,19
7509842,7511873,00,19
7509840,7511875,00,19
7509838,7511877,00,19
7509659,7511879,00,19
7510555,7511885,00,19
7510553,7511887,00,19
7510551,7511889,00,19
7510549,7511891,00,19
7510545,7511893,00,19
7510543,7511895,00,19
7510541,7511897,00,19
7510539,7511899,00,19
7510533,7511905,00,19
7510582,7511837,00,19
7510576,7511835,00,19
7510561,7511833,00,19
7510203,7511829,00,19
7510608,7511811,00,19
7509900,7511827,00,19
7510606,7511809,00,19
7510604,7511807,00,19
7509872,7511823,00,19
7510602,7511805,00,19
7510598,7511803,00,19
7510596,7511801,00,19
7510594,7511799,00,19
7510592,7511797,00,19
7510531,7511773,00,19
7510529,7511771,00,19
7510527,7511769,00,19
7510590,7511795,00,19
7510523,7511765,00,19
7510525,7511767,00,19
7510521,7511763,00,19
7510588,7511793,00,19
7510519,7511761,00,19
7510517,7511759,00,19
7510515,7511757,00,19
7510586,7511791,00,19
7510513,7511755,00,19
7510511,7511753,00,19
7510584,7511789,00,19
7510509,7511751,00,19
7510580,7511787,00,19
7510221,7511723,00,19
7510578,7511785,00,19
7510219,7511721,00,19
7510574,7511783,00,19
7510217,7511719,00,19
7510215,7511717,00,19
7510572,7511781,00,19
7510570,7511779,00,19
7510213,7511715,00,19
7510211,7511713,00,19
7510567,7511777,00,19
7510207,7511711,00,19
7510565,7511775,00,19
7510205,7511709,00,19
7510507,7511749,00,19
7510505,7511747,00,19
7510503,7511745,00,19
7510501,7511743,00,19
7510499,7511741,00,19
7510497,7511739,00,19
7510495,7511737,00,19
7510493,7511735,00,19
7510491,7511733,00,19
7510489,7511731,00,19
7510487,7511729,00,19
7510485,7511727,00,19
7509428,7511725,00,19
7510600,7512186,00,19
7510209,7512185,00,19
7511437,7512187,00,19
7511438,7512188,00,19
7511439,7512189,00,19
7511440,7512190,00,19
7511441,7512191,00,19
7511443,7512193,00,19
7511442,7512192,00,19
7511444,7512194,00,19
7509868,7512196,00,19
7509651,7512195,00,19
7510483,7512197,00,19
7511355,7512198,00,19
7511357,7512199,00,19
7511359,7512200,00,19
7511361,7512201,00,19
7511363,7512202,00,19
7511467,7512203,00,19
7511469,7512204,00,19
7511471,7512205,00,19
7510148,7512226,00,19
7511883,7512215,00,19
7511631,7512225,00,19
7511633,7512224,00,19
7511635,7512223,00,19
7511637,7512222,00,19
7511869,7512221,00,19
7511871,7512220,00,19
7511873,7512219,00,19
7511875,7512218,00,19
7511877,7512217,00,19
7511879,7512216,00,19
7511885,7512214,00,19
7511887,7512213,00,19
7511889,7512212,00,19
7511891,7512211,00,19
7511893,7512210,00,19
7511895,7512209,00,19
7511897,7512208,00,19
7511899,7512207,00,19
7511905,7512206,00,19
7511709,7512227,00,19
7511711,7512228,00,19
7511713,7512229,00,19
7511715,7512230,00,19
7511717,7512231,00,19
7511719,7512232,00,19
7511721,7512233,00,19
7511723,7512234,00,19
7511725,7512235,00,19
7511727,7512236,00,19
7511729,7512237,00,19
7511731,7512238,00,19
7511733,7512239,00,19
7511735,7512240,00,19
7511737,7512241,00,19
7511739,7512242,00,19
7511741,7512243,00,19
7511743,7512244,00,19
7511745,7512245,00,19
7511747,7512246,00,19
7511749,7512247,00,19
7511751,7512248,00,19
7511753,7512249,00,19
7511755,7512250,00,19
7511757,7512251,00,19
7511759,7512252,00,19
7511761,7512253,00,19
7511763,7512254,00,19
7511765,7512255,00,19
7511767,7512256,00,19
7511769,7512257,00,19
7511771,7512258,00,19
7511773,7512259,00,19
7511775,7512260,00,19
7511777,7512261,00,19
7511779,7512262,00,19
7511781,7512263,00,19
7511783,7512264,00,19
7511785,7512265,00,19
7511787,7512266,00,19
7511789,7512267,00,19
7511791,7512268,00,19
7511793,7512269,00,19
7511795,7512270,00,19
7511797,7512271,00,19
7511799,7512272,00,19
7511801,7512273,00,19
7511803,7512274,00,19
7511805,7512275,00,19
7511807,7512276,00,19
7511809,7512277,00,19
7511811,7512278,00,19
7511813,7512279,00,19
7511815,7512280,00,19
7511817,7512281,00,19
7511819,7512282,00,19
7511821,7512283,00,19
7511823,7512284,00,19
7511827,7512285,00,19
7511829,7512286,00,19
7511833,7512287,00,19
7511835,7512288,00,19
7511837,7512289,00,19
7512283,7514421,00,19
7512282,7514423,00,19
7512281,7514425,00,19
7512280,7514427,00,19
7512279,7514429,00,19
7512197,7510879,00,19
7512248,7515518,00,19
7514423,7514441,00,19
7512241,7515516,00,19
4464462,7514443,00,19
7512221,7515514,00,19
4464454,7513219,00,19
7512215,7514437,00,19
7512288,7514435,00,19
7512186,7514433,00,19
7510879,7514431,00,19
7512286,7515573,00,19
7512285,7515571,00,19
7512289,7515577,00,19
7512666,7515583,00,19
7514435,7515540,00,19
7512284,7515569,00,19
7512668,7515581,00,19
7512287,7515575,00,19
7515512,7515559,00,19
7512240,7516512,00,19
7512236,7516520,00,19
7512239,7516514,00,19
7512238,7516516,00,19
7512235,7516516,00,19
7512246,7516502,00,19
7512243,7516508,00,19
7512242,7516510,00,19
7515516,7515563,00,19
7512245,7515563,00,19
7514439,7515545,00,19
7514427,7515587,00,19
7514429,7515585,00,19
7514425,7515589,00,19
7514421,7515547,00,19
7514441,7515547,00,19
7512268,7516460,00,19
7514443,7516460,00,19
7512260,7516460,00,19
7515508,7515555,00,19
7512269,7516458,00,19
7512261,7516474,00,19
7512262,7516474,00,19
7512266,7516464,00,19
4464466,7516464,00,19
7512263,7516470,00,19
4464464,7516470,00,19
7512265,7516466,00,19
7514433,7515538,00,19
7512256,7516629,00,19
7512255,7516486,00,19
7512254,7516486,00,19
7512259,7516478,00,19
7512258,7516480,00,19
7512257,7516482,00,19
7512250,7516626,00,19
7512249,7516498,00,19
7515518,7516498,00,19
7512253,7516490,00,19
7512252,7516492,00,19
7512251,7516494,00,19
7512271,7516442,00,19
7512277,7516442,00,19
7512276,7516622,00,19
7512278,7515567,00,19
7512273,7516450,00,19
7512275,7516446,00,19
7516690,7510881,00,19
7512230,7516624,00,19
7512229,7516534,00,19
7512227,7516534,00,19
7512234,7516524,00,19
7512233,7516526,00,19
7512228,7516536,00,19
7512226,7516540,00,19
7512670,7515579,00,19
7512204,7516582,00,19
7512200,7516590,00,19
7514431,7515536,00,19
7514437,7515543,00,19
7512196,7516596,00,19
7512195,7516598,00,19
7512216,7516559,00,19
7512217,7516557,00,19
7512218,7516555,00,19
7512222,7516548,00,19
7512225,7516542,00,19
7512224,7516544,00,19
7512205,7516580,00,19
7512212,7516565,00,19
7512211,7516567,00,19
7512214,7516561,00,19
7512213,7516563,00,19
7512201,7516588,00,19
7512198,7516594,00,19
7512199,7516592,00,19
7512202,7516586,00,19
7515514,7515561,00,19
7515506,7515553,00,19
7512219,7516553,00,19
7512207,7516576,00,19
4464460,7516569,00,19
7512210,7516569,00,19
7512209,7516571,00,19
4464458,7516571,00,19
7513219,7516578,00,19
7512206,7516578,00,19
7515510,7515557,00,19
7516588,7519080,00,19
7516594,7519078,00,19
7515553,7519066,00,19
7516586,7519074,00,19
7516592,7519076,00,19
7515561,7519070,00,19
7516548,7519107,00,19
7516640,7519110,00,19
7516578,7519072,00,19
7516576,7519096,00,19
7515557,7519068,00,19
7516567,7519086,00,19
7519688,7519088,00,19
7516638,7519090,00,19
7516563,7519082,00,19
7516561,7519084,00,19
7516571,7519092,00,19
7516569,7519094,00,19
7516580,7519098,00,19
7516642,7519100,00,19
7516544,7519102,00,19
7516542,7519104,00,19
7516555,7519113,00,19
7516553,7519117,00,19
7516559,7519119,00,19
7516557,7519115,00,19
7516644,7519121,00,19
7516598,7519125,00,19
7519690,7519127,00,19
7515543,7519130,00,19
7515536,7519133,00,19
7516590,7519136,00,19
7516582,7519139,00,19
7515579,7519142,00,19
7516540,7519144,00,19
7512231,7518874,00,19
7516534,7518874,00,19
7516526,7518870,00,19
7516624,7518876,00,19
7510881,7518879,00,19
7512232,7518867,00,19
7516536,7518867,00,19
7516524,7518872,00,19
7516442,7518891,00,19
7516446,7518881,00,19
7516678,7518889,00,19
7516622,7518887,00,19
7516450,7518883,00,19
7515567,7518885,00,19
7516498,7518900,00,19
7516494,7518893,00,19
7516626,7518904,00,19
7516636,7518906,00,19
7516486,7518914,00,19
7516482,7518908,00,19
7516629,7518916,00,19
7516522,7518918,00,19
7516492,7518895,00,19
7516490,7518898,00,19
7516480,7518910,00,19
7516478,7518912,00,19
7515538,7518920,00,19
7512272,7516208,00,19
7512274,7516546,00,19
7512203,7516456,00,19
7512208,7515549,00,19
4464456,7515549,00,19
7512223,7516504,00,19
7512220,7516472,00,19
7516460,7518936,00,19
7516466,7518922,00,19
7516632,7518928,00,19
7516470,7518924,00,19
7516464,7518926,00,19
7516444,7518930,00,19
7516452,7518932,00,19
7516528,7518934,00,19
7515534,7518938,00,19
7515532,7518940,00,19
7515530,7518946,00,19
7515528,7518942,00,19
7515524,7518944,00,19
7515563,7518948,00,19
7516502,7518954,00,19
7516634,7518978,00,19
7516510,7518950,00,19
7516508,7518952,00,19
7516516,7518980,00,19
7516514,7518982,00,19
7515559,7519052,00,19
7516520,7518984,00,19
7516512,7518986,00,19
7515575,7519054,00,19
7515581,7519056,00,19
7515569,7519058,00,19
7515540,7519060,00,19
7515583,7519062,00,19
7516448,7519064,00,19
7515571,7519164,00,19
7515573,7519173,00,19
7512267,7515565,00,19
7512270,7516496,00,19
7512264,7516484,00,19
7512247,7516476,00,19
7512244,7515593,00,19
7512237,7516462,00,19
7515547,7515534,00,19
7515589,7515532,00,19
7515545,7515530,00,19
7515585,7515528,00,19
7515587,7515524,00,19
7515555,7516528,00,19
7516474,7516444,00,19
7516458,7516452,00,19
7515577,7516448,00,19
7516596,7519690,00,19
7516565,7519688,00,19
7519056,7520191,00,19
7519062,7520189,00,19
7519164,7520187,00,19
7519173,7520185,00,19
7518874,7520472,00,19
7518870,7520474,00,19
7518876,7520476,00,19
7518879,7520478,00,19
7518867,7520480,00,19
7518872,7520482,00,19
7518891,7520484,00,19
7518881,7520500,00,19
7518889,7520502,00,19
7518887,7520506,00,19
7518883,7520508,00,19
7518885,7520510,00,19
7518900,7520513,00,19
7518893,7520515,00,19
7518904,7520517,00,19
7518906,7520520,00,19
7518914,7520522,00,19
7518908,7520524,00,19
7518916,7520526,00,19
7518918,7520528,00,19
7518895,7520530,00,19
7518898,7520532,00,19
7518910,7520534,00,19
7518912,7520536,00,19
7518920,7520538,00,19
7516208,7520540,00,19
7516546,7520542,00,19
7518936,7520615,00,19
7518922,7520617,00,19
7518928,7520619,00,19
7518924,7520621,00,19
7518926,7520623,00,19
7518930,7520625,00,19
7518932,7520627,00,19
7518934,7520632,00,19
7518938,7520634,00,19
7518940,7520636,00,19
7518946,7520638,00,19
7518942,7520640,00,19
7518944,7520642,00,19
7518948,7520644,00,19
7518954,7520646,00,19
7518978,7520649,00,19
7518950,7520650,00,19
7518952,7520652,00,19
7518980,7520654,00,19
7518982,7520656,00,19
7519052,7520658,00,19
7518984,7520660,00,19
7518986,7520662,00,19
7515565,7520544,00,19
7516496,7520546,00,19
7516484,7520548,00,19
7516476,7520550,00,19
7515593,7520552,00,19
7516462,7520554,00,19
7519058,7520564,00,19
7519060,7520568,00,19
7519064,7520573,00,19
7520191,7520581,00,19
7520187,7520583,00,19
7520189,7520585,00,19
7520185,7520587,00,19
7519080,7520948,00,19
7519078,7520950,00,19
7519066,7520952,00,19
7519074,7520954,00,19
7519076,7520956,00,19
7519070,7520958,00,19
7519107,7520960,00,19
7519110,7520962,00,19
7519072,7520964,00,19
7519096,7520966,00,19
7519068,7520968,00,19
7519086,7520970,00,19
7519088,7520973,00,19
7519090,7520975,00,19
7519082,7520977,00,19
7519084,7520979,00,19
7519092,7520981,00,19
7519094,7520983,00,19
7519098,7520985,00,19
7519100,7520987,00,19
7519102,7520989,00,19
7519104,7520991,00,19
7519113,7520993,00,19
7519117,7520995,00,19
7519119,7520997,00,19
7519115,7520999,00,19
7519121,7521001,00,19
7519125,7521003,00,19
7519127,7521005,00,19
7519130,7520593,00,19
7519133,7520595,00,19
7519136,7520597,00,19
7519139,7520599,00,19
7519142,7520601,00,19
7519144,7520603,00,19
7516456,7520556,00,19
7515549,7520558,00,19
7516504,7520560,00,19
7516472,7520562,00,19
7520619,7521976,00,19
7520632,7521978,00,19
7520638,7521980,00,19
7520649,7521982,00,19
7520658,7521984,00,19
7520948,7522310,00,19
7520952,7522312,00,19
7520954,7522314,00,19
7520958,7522316,00,19
7520962,7522318,00,19
7520964,7522320,00,19
7520968,7522322,00,19
7520970,7522324,00,19
7520975,7522326,00,19
7520977,7522328,00,19
7520981,7522330,00,19
7520985,7522332,00,19
7520987,7522334,00,19
7520989,7522336,00,19
7520993,7522338,00,19
7520997,7522340,00,19
7521001,7522342,00,19
7521003,7522344,00,19
7520593,7522346,00,19
7520595,7522348,00,19
7520597,7522350,00,19
7520599,7522352,00,19
7520601,7522354,00,19
7520603,7522356,00,19
7520552,7523308,00,19
7520554,7523360,00,19
7519054,7520566,00,19
7520583,7525643,00,19
7520581,7525734,00,19
7520585,7525744,00,19
7520587,7525746,00,19
7525380,7528014,00,19
7522747,7528217,00,19
7522745,7528219,00,19
7522749,7528221,00,19
7522751,7528223,00,19
7521976,7528009,00,19
7520615,7528009,00,19
4474748,7528009,00,19
7520617,7528141,00,19
7520621,7528012,00,19
4474750,7528012,00,19
7520623,7528143,00,19
7520544,7528233,00,19
7520634,7528145,00,19
4474744,7528145,00,19
7521980,7528145,00,19
7520636,7528040,00,19
7520640,7528163,00,19
4474746,7528163,00,19
7520642,7528212,00,19
7521978,7528036,00,19
4475868,7528036,00,19
7520625,7528036,00,19
7520627,7528149,00,19
7525348,7528016,00,19
7525350,7528044,00,19
4475866,7528044,00,19
7525352,7528046,00,19
7525355,7528048,00,19
7525357,7528052,00,19
4474752,7528068,00,19
7522320,7528068,00,19
7522322,7528068,00,19
7520966,7528070,00,19
4474760,7528062,00,19
7522330,7528062,00,19
7520983,7528064,00,19
7520700,7528235,00,19
7520558,7528237,00,19
7522326,7528072,00,19
7522324,7528072,00,19
4474762,7528072,00,19
7520973,7528058,00,19
7522328,7528074,00,19
4474764,7528074,00,19
7520979,7528060,00,19
7522334,7528076,00,19
4474766,7528076,00,19
7522332,7528076,00,19
7525361,7528151,00,19
7525363,7528153,00,19
7525365,7528155,00,19
7522875,7528080,00,19
7522877,7528147,00,19
4474944,7528078,00,19
7522881,7528078,00,19
7520484,7529518,00,19
7520502,7529518,00,19
7520500,7529520,00,19
7520506,7529522,00,19
7520508,7529524,00,19
7520510,7529526,00,19
7520513,7529528,00,19
7520520,7529528,00,19
7520515,7529530,00,19
7520517,7529532,00,19
7520522,7529534,00,19
7520528,7529534,00,19
7520524,7529536,00,19
7520526,7529538,00,19
7520530,7529540,00,19
7520532,7529542,00,19
7520534,7529544,00,19
7520536,7529546,00,19
7520472,7529548,00,19
7520478,7529548,00,19
7520474,7529550,00,19
7520476,7529552,00,19
7520480,7529554,00,19
7520482,7529556,00,19
7520538,7529558,00,19
7520540,7529560,00,19
7520542,7529562,00,19
7521982,7529564,00,19
7520644,7529564,00,19
7520646,7529566,00,19
7520650,7529568,00,19
7520652,7529570,00,19
7521984,7529572,00,19
7520654,7529572,00,19
7520656,7529574,00,19
7520660,7529576,00,19
7520662,7529578,00,19
7520564,7529580,00,19
7525331,7529582,00,19
7525346,7529584,00,19
7520566,7529586,00,19
7520568,7529588,00,19
7520573,7529590,00,19
7525734,7529592,00,19
7525643,7529594,00,19
7525744,7529596,00,19
7525746,7529598,00,19
7520546,7529600,00,19
7520548,7529602,00,19
7520550,7529604,00,19
7523308,7529606,00,19
7523360,7529608,00,19
7522316,7529610,00,19
7522318,7529610,00,19
7520960,7529612,00,19
7522336,7529614,00,19
7520991,7529616,00,19
7526520,7529618,00,19
7522338,7529620,00,19
7520995,7529622,00,19
7522340,7529624,00,19
7522342,7529624,00,19
7520999,7529626,00,19
7522310,7529628,00,19
7522312,7529628,00,19
7520950,7529630,00,19
7522314,7529632,00,19
7520956,7529634,00,19
7522346,7529636,00,19
7522352,7529638,00,19
7522354,7529641,00,19
7522356,7529643,00,19
7525359,7529645,00,19
7522350,7529647,00,19
7520556,7529649,00,19
7520560,7529651,00,19
7520562,7528788,00,19
7522344,7528790,00,19
7521005,7528792,00,19
7522348,7528794,00,19
7529518,7529818,00,19
7529520,7529820,00,19
7529522,7529822,00,19
7529524,7529824,00,19
7529526,7529826,00,19
7529528,7528497,00,19
7529530,7530259,00,19
7529532,7530671,00,19
7529534,7530836,00,19
7529536,7530917,00,19
7529538,7531076,00,19
7529540,7531077,00,19
7529542,7531078,00,19
7529544,7531099,00,19
7529546,7531100,00,19
7528014,7531101,00,19
7529548,7531102,00,19
7529550,7531103,00,19
7529552,7531104,00,19
7529554,7531105,00,19
7529556,7531106,00,19
7529558,7531107,00,19
7529560,7531108,00,19
7529562,7531109,00,19
7529564,7531110,00,19
7529566,7531112,00,19
7529568,7531113,00,19
7529570,7531114,00,19
7529572,7531115,00,19
7529574,7531116,00,19
7529576,7531117,00,19
7529578,7531118,00,19
7528018,7531119,00,19
7528020,7531120,00,19
7528032,7531121,00,19
7528034,7531122,00,19
7528009,7531123,00,19
7528141,7531124,00,19
7528012,7531125,00,19
7528143,7531126,00,19
7528233,7531127,00,19
7528145,7531128,00,19
7528040,7531129,00,19
7528139,7531130,00,19
7528038,7531131,00,19
7528163,7531132,00,19
7528212,7531133,00,19
7528054,7531134,00,19
7528056,7531135,00,19
7528036,7531136,00,19
7528149,7531137,00,19
7528016,7531138,00,19
7528044,7531139,00,19
7528046,7531140,00,19
7528048,7531141,00,19
7528052,7531142,00,19
7528217,7531143,00,19
7528219,7531144,00,19
7528221,7531145,00,19
7528223,7531146,00,19
7529580,7531147,00,19
7529582,7531148,00,19
7529584,7531149,00,19
7529586,7531150,00,19
7529588,7531151,00,19
7529590,7531152,00,19
7529592,7531153,00,19
7529594,7531158,00,19
7529596,7531159,00,19
7529598,7531160,00,19
7529600,7531161,00,19
7529602,7531162,00,19
7529604,7531163,00,19
7529606,7531167,00,19
7529608,7531168,00,19
7528225,7531169,00,19
7528227,7531170,00,19
7528229,7531171,00,19
7528231,7531172,00,19
7529610,7531173,00,19
7529612,7531174,00,19
7529614,7531176,00,19
7529616,7531177,00,19
7529618,7531178,00,19
7529620,7531179,00,19
7529622,7531180,00,19
7529624,7531181,00,19
7529626,7531182,00,19
7528237,7531183,00,19
7528235,7531184,00,19
7528072,7531185,00,19
7528058,7531186,00,19
7528074,7531187,00,19
7528060,7531188,00,19
7528076,7531189,00,19
7528151,7531190,00,19
7528153,7531191,00,19
7528155,7531192,00,19
7528080,7531193,00,19
7528147,7531194,00,19
7528078,7531195,00,19
7528068,7531196,00,19
7528070,7531197,00,19
7528062,7531198,00,19
7528064,7531199,00,19
7529628,7531200,00,19
7529630,7531201,00,19
7529632,7531202,00,19
7529634,7531203,00,19
7529636,7531204,00,19
7529638,7531205,00,19
7529641,7531206,00,19
7529643,7531207,00,19
7529645,7531208,00,19
7529647,7531209,00,19
7529649,7531210,00,19
7529651,7531211,00,19
7528788,7531212,00,19
7528790,7531213,00,19
7528792,7531214,00,19
7528794,7531215,00,19
7531119,7532419,00,19
7531120,7532421,00,19
7531121,7532423,00,19
7531122,7532425,00,19
7531130,7532442,00,19
7531131,7532444,00,19
7531134,7532452,00,19
7531135,7532454,00,19
7531169,7532456,00,19
7531170,7532458,00,19
7531171,7532460,00,19
7531172,7532462,00,19
7531185,7532464,00,19
7531186,7532466,00,19
7531187,7532468,00,19
7531188,7532470,00,19
7531173,7532828,00,19
7531181,7532832,00,19
7532464,7532836,00,19
7531189,7532839,00,19
7531200,7532841,00,19
7531196,7532834,00,19
7532456,7532923,00,19
7529818,7531978,00,19
7529820,7531980,00,19
7529822,7531982,00,19
7529824,7531984,00,19
7529826,7531995,00,19
7528497,7531997,00,19
7530259,7531999,00,19
7530671,7532001,00,19
7530836,7532003,00,19
7530917,7532005,00,19
7531076,7532007,00,19
7531077,7532009,00,19
7531078,7532011,00,19
7531099,7532014,00,19
7531100,7532016,00,19
7531101,7532018,00,19
7531102,7532020,00,19
7531103,7532022,00,19
7531104,7532024,00,19
7531105,7532026,00,19
7531106,7532028,00,19
7531107,7532030,00,19
7531108,7532032,00,19
7531109,7532034,00,19
7531978,7532319,00,19
7531138,7532343,00,19
7531190,7532345,00,19
7531980,7532090,00,19
7531982,7532092,00,19
7531984,7532098,00,19
7531995,7532100,00,19
7531997,7532104,00,19
7531999,7532106,00,19
7532001,7532108,00,19
7532003,7532110,00,19
7532005,7532112,00,19
7532007,7532114,00,19
7532009,7532116,00,19
7532011,7532118,00,19
7532014,7532120,00,19
7532016,7532122,00,19
7532018,7532374,00,19
7532020,7532378,00,19
7532022,7532383,00,19
7532024,7532390,00,19
7532026,7532393,00,19
7532028,7532395,00,19
7532030,7532397,00,19
7532032,7532399,00,19
7532034,7532401,00,19
7531110,7532403,00,19
7531112,7532405,00,19
7531113,7532407,00,19
7531114,7532409,00,19
7531115,7532411,00,19
7531116,7532413,00,19
7531117,7532415,00,19
7531118,7532417,00,19
7532419,7531930,00,19
7532423,7531934,00,19
7532425,7531936,00,19
7531123,7532427,00,19
7531124,7532429,00,19
7531125,7532431,00,19
7531126,7532434,00,19
7531127,7532436,00,19
7531128,7532438,00,19
7531129,7532440,00,19
7532442,7532499,00,19
7532444,7532501,00,19
7531132,7532446,00,19
7531133,7532504,00,19
7532452,7532506,00,19
7532454,7532508,00,19
7531136,7532510,00,19
7531137,7532512,00,19
7531139,7532516,00,19
7531140,7532518,00,19
7531141,7532520,00,19
7531142,7532522,00,19
7531143,7532544,00,19
7531144,7532546,00,19
7531145,7532562,00,19
7531146,7532564,00,19
7531147,7532566,00,19
7531148,7532568,00,19
7531149,7532570,00,19
7531150,7531079,00,19
7531151,7529957,00,19
7531152,7529959,00,19
7531153,7531093,00,19
7531158,7531095,00,19
7531159,7531097,00,19
7531168,7531299,00,19
7531160,7531261,00,19
7531161,7531283,00,19
7531162,7531289,00,19
7531163,7531295,00,19
7531167,7531297,00,19
7532923,7531301,00,19
7532458,7531303,00,19
7532460,7531305,00,19
7532462,7532574,00,19
7532828,7532576,00,19
7531174,7532578,00,19
7531176,7532580,00,19
7531177,7532582,00,19
7531178,7532584,00,19
7531179,7532586,00,19
7531180,7532588,00,19
7532832,7532590,00,19
7531182,7533002,00,19
7531183,7533004,00,19
7531184,7533006,00,19
7532836,7533011,00,19
7532466,7533013,00,19
7532468,7533015,00,19
7532470,7533018,00,19
7532839,7533020,00,19
7531191,7533022,00,19
7531192,7533024,00,19
7531193,7533026,00,19
7531194,7533028,00,19
7531195,7533030,00,19
4480624,7532906,00,19
4480626,7533034,00,19
7532834,7533036,00,19
7531197,7533123,00,19
7531198,7533125,00,19
7531199,7533127,00,19
7532841,7533129,00,19
7531201,7533153,00,19
7531202,7533155,00,19
7531203,7533157,00,19
7531204,7533159,00,19
7531205,7533161,00,19
7531206,7533163,00,19
7531207,7533165,00,19
7531208,7533167,00,19
7531209,7533169,00,19
7531210,7533171,00,19
7531211,7533173,00,19
7531212,7533175,00,19
7531213,7533177,00,19
7531214,7533179,00,19
7531215,7533181,00,19
7532421,7531932,00,19
7532319,7536607,00,19
7532090,7536609,00,19
7532092,7536611,00,19
7532098,7536613,00,19
7532100,7536615,00,19
7532104,7536617,00,19
7532106,7536619,00,19
7532108,7536622,00,19
7532110,7536624,00,19
7532112,7536626,00,19
7532114,7536628,00,19
7532116,7536630,00,19
7532118,7536632,00,19
7532120,7536639,00,19
7532122,7536641,00,19
7532378,7536800,00,19
7532383,7536802,00,19
7532390,7536804,00,19
7532393,7536806,00,19
7532395,7536808,00,19
7532399,7536810,00,19
7532401,7536812,00,19
7534240,7536939,00,19
7534242,7536941,00,19
7532906,7536943,00,19
7533034,7536945,00,19
7533524,7536947,00,19
7533526,7536949,00,19
7533528,7536951,00,19
7533530,7536953,00,19
7532427,7541398,00,19
7533011,7541399,00,19
7532345,7541400,00,19
7536947,7541425,00,19
4485532,7541425,00,19
7532343,7539563,00,19
7532568,7539605,00,19
7532570,7539607,00,19
7531079,7539609,00,19
7529957,7539611,00,19
7529959,7539613,00,19
7536607,7539418,00,19
7536609,7539457,00,19
7536611,7539459,00,19
7536613,7539461,00,19
7536615,7539463,00,19
7536624,7539471,00,19
7536626,7539473,00,19
7536628,7539475,00,19
7536639,7539481,00,19
7536641,7539484,00,19
7532374,7539486,00,19
7536800,7539488,00,19
7536802,7539490,00,19
7536804,7539492,00,19
7536806,7539494,00,19
7536808,7539496,00,19
7536617,7539465,00,19
7536619,7539467,00,19
7536622,7539469,00,19
7536630,7539477,00,19
7536632,7539479,00,19
7536810,7539498,00,19
7536812,7539500,00,19
7532397,7539502,00,19
7532411,7539513,00,19
7532413,7539515,00,19
7532415,7539517,00,19
7532417,7539519,00,19
7531930,7539521,00,19
7531932,7539523,00,19
7531934,7539527,00,19
7531936,7539529,00,19
7532429,7539533,00,19
7532431,7539535,00,19
7532434,7539537,00,19
7532436,7539539,00,19
7532438,7539541,00,19
7532440,7539545,00,19
7532499,7539547,00,19
7532501,7539549,00,19
7532446,7539551,00,19
7532504,7539553,00,19
7532506,7539555,00,19
7532508,7539557,00,19
7532510,7539559,00,19
7532512,7539561,00,19
7539563,7542104,00,19
7532516,7539567,00,19
7532518,7539569,00,19
7532544,7539584,00,19
7532546,7539586,00,19
7532562,7539588,00,19
7532564,7539590,00,19
7531283,7539592,00,19
7531289,7539595,00,19
7532403,7539504,00,19
7532405,7539506,00,19
7532407,7539508,00,19
7532409,7539510,00,19
7531295,7539597,00,19
7531297,7539599,00,19
7531299,7539601,00,19
7532566,7539603,00,19
7539605,7542106,00,19
7539607,7542108,00,19
7539609,7542110,00,19
7539611,7542112,00,19
7539613,7542114,00,19
7531093,7539614,00,19
7531095,7539616,00,19
7532520,7539571,00,19
7532522,7539573,00,19
7531097,7539618,00,19
7531261,7539620,00,19
7531301,7539622,00,19
7531303,7539624,00,19
7531305,7539626,00,19
7532574,7539628,00,19
7532586,7539640,01,19
7532588,7539642,00,19
7532590,7539644,00,19
7533002,7539646,00,19
7533004,7539648,00,19
7533006,7539650,00,19
7533013,7539654,00,19
7533015,7539656,00,19
7533018,7539658,00,19
7533020,7539660,00,19
7536949,7539664,00,19
7536939,7539666,00,19
7536941,7539668,00,19
7536943,7539673,00,19
7536945,7539675,00,19
7541400,7541484,00,19
7536951,7539677,00,19
7536953,7539679,00,19
7533036,7539691,00,19
7533123,7539693,00,19
7533125,7539695,00,19
7533127,7539697,00,19
7533129,7539699,00,19
7533153,7539701,00,19
7533155,7539706,00,19
7533171,7539708,00,19
7532576,7539630,00,19
7532578,7539632,00,19
7532580,7539634,00,19
7532582,7539636,00,19
7532584,7539638,00,19
7533173,7539710,00,19
7533175,7539716,00,19
7533157,7539718,01,19
7533177,7539720,00,19
7533179,7539721,00,19
7533026,7539724,00,19
7533028,7539726,00,19
7533159,7539728,00,19
7533161,7539730,00,19
7533022,7539681,00,19
7533024,7539683,00,19
7533163,7539732,00,19
7533165,7539734,00,19
7533167,7539736,00,19
7533169,7539738,00,19
7533181,7539740,00,19
7533030,7539746,00,19
7533516,7539748,00,19
7533518,7539750,00,19
7533520,7539752,00,19
7533522,7539754,00,19
7541425,7545018,00,19
7539664,7545020,00,19
7539666,7545022,00,19
7539668,7545024,00,19
7539673,7545026,00,19
7539675,7545028,00,19
7539677,7545030,00,19
7539679,7545032,00,19
7539418,7545416,00,19
7539457,7545418,00,19
7539459,7545420,00,19
7539461,7545422,00,19
7539463,7545424,00,19
7539471,7545426,00,19
7539473,7545428,00,19
7539475,7545430,00,19
7539481,7545432,00,19
7539484,7545434,00,19
7539486,7545436,00,19
7539513,7545440,00,19
7539515,7545443,00,19
7539517,7545447,00,19
7539519,7545450,00,19
7539521,7545452,00,19
7539523,7545454,00,19
7539527,7545456,00,19
7539529,7545458,00,19
7541398,7545460,00,19
7539533,7545462,00,19
7539535,7545464,00,19
7539537,7545466,00,19
7539539,7545468,00,19
7539541,7545470,00,19
7539545,7545477,00,19
7539547,7545479,00,19
7539549,7545481,00,19
7539551,7545518,00,19
7539553,7545520,00,19
7539555,7545522,00,19
7539557,7545524,00,19
7539559,7545526,00,19
7539561,7545528,00,19
7542104,7545530,00,19
7539567,7545532,00,19
7539569,7545534,00,19
7539622,7545536,00,19
7539624,7545538,00,19
7539626,7545540,00,19
7539628,7545542,00,19
7539640,7545544,00,19
7539642,7545546,00,19
7539644,7545548,00,19
7539646,7545550,00,19
7539648,7545552,00,19
7539650,7545554,00,19
7541399,7545556,00,19
7539654,7545558,00,19
7539656,7545560,00,19
7539658,7545562,00,19
7539660,7545566,00,19
7545018,7545569,00,19
7545020,7545571,00,19
7545022,7545573,00,19
7545024,7545575,00,19
7545026,7545577,00,19
7545028,7545579,00,19
7545030,7545582,00,19
7545032,7545584,00,19
7541484,7545586,00,19
7539488,7545588,00,19
7539490,7545589,00,19
7539492,7545590,00,19
7539494,7545591,00,19
7539496,7545592,00,19
7539465,7545593,00,19
7539467,7545594,00,19
7539469,7545595,00,19
7539477,7545596,00,19
7539479,7545597,00,19
7539498,7545602,00,19
7539500,7545603,00,19
7539748,7545608,00,19
7539750,7545609,00,19
7539502,7545619,00,19
7539584,7545620,00,19
7539586,7545625,00,19
7539588,7545626,00,19
7539590,7545643,00,19
7539592,7545644,00,19
7539595,7545645,00,19
7539504,7545646,00,19
7539506,7545647,00,19
7539508,7545648,00,19
7539510,7545649,00,19
7539597,7545650,00,19
7539599,7545651,00,19
7539601,7545652,00,19
7539752,7545668,00,19
7539754,7545669,00,19
7539603,7545654,00,19
7542106,7545655,00,19
7542108,7545656,00,19
7542110,7545657,00,19
7542112,7545658,00,19
7542114,7545659,00,19
7539614,7545660,00,19
7539616,7545661,00,19
7539571,7545662,00,19
7539573,7545663,00,19
7539618,7545664,00,19
7539620,7545667,00,19
7539691,7545670,00,19
7539693,7545671,00,19
7539695,7545672,00,19
7539697,7545673,00,19
7539699,7545674,00,19
7539701,7545675,00,19
7539706,7545676,00,19
7539708,7545677,00,19
7539630,7545678,00,19
7539632,7545679,00,19
7539634,7545680,00,19
7539636,7545681,00,19
7539638,7545682,00,19
7539710,7545683,00,19
7539716,7545684,00,19
7539718,7545685,00,19
7539720,7545686,00,19
7539721,7545687,00,19
7539724,7545688,00,19
7539726,7545689,00,19
7539728,7545690,00,19
7539730,7545691,00,19
7539681,7545692,00,19
7539683,7545693,00,19
7539732,7545694,00,19
7539734,7545695,00,19
7539736,7545696,00,19
7539738,7545697,00,19
7539740,7545698,00,19
7539746,7545699,00,19
7545436,7548602,00,19
7545530,7548604,00,19
7545577,7548606,00,19
7545579,7548608,00,19
7545582,7548610,00,19
7545584,7548612,00,19
7545586,7548614,00,19
7549718,7552010,00,19
7549719,7552011,00,19
7545420,7552014,00,19
7549722,7552016,00,19
7549724,7552018,00,19
7549726,7552020,00,19
7549728,7552022,00,19
7549730,7552024,00,19
7549732,7552026,00,19
7549734,7552028,00,19
7549736,7552030,00,19
7549738,7552032,00,19
7549740,7552034,00,19
7549742,7552036,00,19
7549744,7552038,00,19
7549746,7552040,00,19
7549748,7552042,00,19
7545536,7552617,00,19
7545538,7552618,00,19
7545540,7552619,00,19
7545542,7552620,00,19
7548606,7552044,00,19
7548608,7552046,00,19
7548610,7552048,00,19
7548612,7552050,00,19
7552044,7555766,00,19
7552046,7555768,00,19
7552048,7555770,00,19
7552050,7555772,00,19
7548604,7555774,00,19
7548614,7555778,00,19
7556258,7557375,00,19
7556260,7557377,00,19
7556262,7557379,00,19
7556264,7557381,00,19
7555766,7557383,00,19
7555768,7557385,00,19
7555770,7557387,00,19
7555772,7557389,00,19
7557375,7558846,00,19
7557377,7558848,00,19
7557379,7558850,00,19
7557381,7558852,00,19
7558846,7560388,00,19
7558848,7560390,00,19
7558850,7560392,00,19
7558852,7560394,00,19
7557383,7560396,00,19
7557385,7560398,00,19
7557387,7560400,00,19
7557389,7560402,00,19
7555778,7560406,00,19
7545569,7560496,00,19
7545571,7560498,00,19
7545573,7560500,00,19
7545575,7560502,00,19
7545691,7560550,00,19
7552020,7564428,00,19
7552022,7564430,00,19
7552024,7564432,00,19
7552026,7564434,00,19
7552028,7564436,00,19
7552030,7564438,00,19
7552032,7564440,00,19
7552034,7564442,00,19
7545452,7564444,00,19
7545454,7564446,00,19
7545528,7564476,00,19
7545526,7564474,00,19
7545524,7564472,00,19
7545522,7564470,00,19
7545520,7564468,00,19
7545518,7564466,00,19
7545481,7564464,00,19
7545479,7564462,00,19
7545477,7564460,00,19
7545470,7564458,00,19
7555774,7564456,00,19
7545466,7564454,00,19
7545462,7564452,00,19
7545460,7564450,00,19
7545458,7564448,00,19
7545456,7564482,00,19
7545464,7564484,00,19
7545620,7564760,00,19
7545468,7564770,00,19
7545626,7564764,00,19
7545625,7564762,00,19
7545643,7564766,00,19
7545645,7564768,00,19
7560396,7571600,00,19
7560398,7571601,00,19
7560400,7571602,00,19
7560402,7571603,00,19
7564456,7571604,00,19
7560406,7571605,00,19
7548602,7571606,00,19
7545619,7571607,00,19
7545655,7571608,00,19
7545656,7571609,00,19
7545657,7571610,00,19
7545658,7571611,00,19
7545659,7571612,00,19
7545690,7571613,00,19
7560550,7571614,00,19
7545696,7571615,00,19
7545698,7571616,00,19
7545699,7571617,00,19
7560500,7575120,00,19
7560502,7575144,00,19
7545688,7575146,00,19
7545689,7575148,00,19
7571617,7575122,00,19
7571616,7575636,00,19
7571601,7582621,00,19
7571603,7582623,00,19
Administrator
Discussion Starter · #87 ·
MS45.1 version history (MDS451.HIS)
;Zusbauhistorie vom 26.04.2007 14:39
;SG-TYP: MDS451
4469198,4470902,00,1C
4470152,4470905,00,1C
4470150,4470907,00,1C
4470905,4470957,00,1C
4470902,4470956,00,1C
4470957,4473695,00,1C
4470907,4473697,00,1C
4473431,7522828,00,1C
4473438,7525295,00,1C
7522828,7526024,00,1C
7525295,7526026,00,1C
7526024,7526736,00,1C
7526026,7526738,00,1C
7526736,7527311,00,1C
7526738,7527312,00,1C
4473695,4475279,00,1C
4473697,4475281,00,1C
7527311,7527765,00,1C
7527312,7527766,00,1C
4475279,4476168,00,1C
4475283,4476172,00,1C
4475285,4476174,00,1C
4475281,4476170,00,1C
7527765,7527940,00,1C
7527766,7527942,00,1C
7527940,7529514,00,1C
7527942,7529516,00,1C
4476168,7530022,00,1C
4476172,7530031,00,1C
4476174,7530033,00,1C
7529514,7530035,00,1C
7529516,7530037,00,1C
4476170,7530024,00,1C
7530035,7531218,00,1C
7530037,7531220,00,1C
7530024,7531489,00,1C
7530031,7531490,00,1C
7530214,7531491,00,1C
7530033,7531492,00,1C
7531218,7531493,00,1C
7531220,7531494,00,1C
7530022,7531488,00,1C
7531901,7532209,00,1C
7531489,7531903,00,1C
7531490,7531905,00,1C
7531491,7531907,00,1C
7531492,7531909,00,1C
7531493,7531972,00,1C
7531494,7531974,00,1C
7531488,7531901,00,1C
7532209,7532772,00,1C
7531903,7532774,00,1C
7531905,7532776,00,1C
7531907,7532778,00,1C
7531909,7532780,00,1C
7531972,7532782,00,1C
7531974,7532784,00,1C
7532772,7533920,00,1C
7532774,7533954,00,1C
7533920,7533692,00,1C
7533954,7533693,00,1C
7532776,7533694,00,1C
7532778,7533695,00,1C
7532780,7533696,00,1C
7532782,7533697,00,1C
7532784,7533698,00,1C
4480201,7534337,00,1C
4480203,7534339,00,1C
7533692,7535998,00,1C
7533693,7536000,00,1C
7534337,7536109,00,1C
7534339,7536111,00,1C
7535998,7536165,00,1C
7536000,7536167,00,1C
7533694,7536169,00,1C
7533695,7536841,00,1C
7533696,7536843,00,1C
7533697,7536845,00,1C
7533698,7536847,00,1C
7536165,7537504,00,1C
7536167,7537506,00,1C
7537504,7537929,00,1C
7537785,7537931,00,1C
7537787,7537933,00,1C
7536169,7537790,00,1C
7536841,7537792,00,1C
7536843,7537794,00,1C
7536845,7537796,00,1C
7536847,7537798,00,1C
7536109,7536849,00,1C
7536111,7536851,00,1C
7537506,7537785,00,1C
7537790,7540380,00,1C
7537792,7540382,00,1C
7537794,7540384,00,1C
7537796,7540386,00,1C
7537798,7540388,00,1C
7536849,7540535,00,1C
7536851,7540537,00,1C
7537929,7537235,00,1C
7537931,7537237,00,1C
7537933,7537237,00,1C
7540380,7537239,00,1C
7540382,7537241,00,1C
7540384,7539210,00,1C
7540386,7540146,00,1C
7540388,7540924,00,1C
7540535,7540926,00,1C
7540537,7540928,00,1C
7537235,7545701,00,1C
4488964,4490470,00,1C
4488966,4490476,00,1C
7537239,7546932,00,1C
7537241,7546938,00,1C
7539210,7546944,00,1C
7540146,7546950,00,1C
7540924,7546954,00,1C
7540926,7546928,00,1C
7540928,7546930,00,1C
7545966,7547657,00,1C
7545968,7547657,00,1C
7545970,7547657,00,1C
7545972,7547663,00,1C
7545974,7547663,00,1C
7545976,7547663,00,1C
7546932,7547793,00,1C
7546934,7547795,00,1C
7546936,7547797,00,1C
7546938,7547799,00,1C
7546940,7547801,00,1C
7546942,7547803,00,1C
7546944,7547805,00,1C
7546946,7547807,00,1C
7546948,7547809,00,1C
7546950,7547811,00,1C
7546954,7547813,00,1C
7546928,7547815,00,1C
7546930,7547817,00,1C
7547793,7548574,00,1C
7547795,7548576,00,1C
7547797,7548578,00,1C
7547799,7548580,00,1C
7547801,7548582,00,1C
7547803,7548584,00,1C
7547805,7548586,00,1C
7547807,7548588,00,1C
7547809,7548590,00,1C
7547811,7548592,00,1C
7547813,7548594,00,1C
7547815,7548596,00,1C
7547817,7548598,00,1C
7547657,7548725,00,1C
7547659,7548727,00,1C
7547661,7548729,00,1C
7547663,7548731,00,1C
7547665,7548733,00,1C
7547668,7548735,00,1C
7548725,7549078,00,1C
7548727,7549079,00,1C
7548729,7549080,00,1C
7548731,7549081,00,1C
7548733,7549082,00,1C
7548735,7549083,00,1C
7548574,7549084,00,1C
7548576,7549085,00,1C
7548578,7549086,00,1C
7548580,7549087,00,1C
7548582,7549088,00,1C
7548584,7549089,00,1C
7548586,7549090,00,1C
7548588,7549091,00,1C
7548590,7549092,00,1C
7548592,7549093,00,1C
7548594,7549094,00,1C
7548596,7549095,00,1C
7548598,7549096,00,1C
7549078,7550063,00,1C
7549079,7550065,00,1C
7549080,7550067,00,1C
7549081,7550069,00,1C
7549082,7550071,00,1C
7549083,7550073,00,1C
7549084,7542987,00,1C
7549085,7542989,00,1C
7549086,7542991,00,1C
7549087,7542993,00,1C
7549088,7542995,00,1C
7549089,7543010,00,1C
7549090,7543012,00,1C
7549091,7543014,00,1C
7549092,7543016,00,1C
7549093,7543018,00,1C
7549094,7543020,00,1C
7549095,7543022,00,1C
7549096,7543024,00,1C
7542987,7561514,00,1C
7542989,7561516,00,1C
7542991,7561518,00,1C
7542993,7561520,00,1C
7542995,7561522,00,1C
7543010,7561524,00,1C
7543012,7561526,00,1C
7543014,7561528,00,1C
7543016,7561532,00,1C
7543018,7561534,00,1C
7543020,7561536,00,1C
7543022,7561538,00,1C
7543024,7561540,00,1C
7550063,7561942,00,1C
7550065,7561944,00,1C
7550067,7561946,00,1C
7550069,7561948,00,1C
7550071,7561950,00,1C
7550073,7561952,00,1C
7561534,7577218,00,1C
7561536,7577220,00,1C
7561940,7582046,00,1C
7562352,7582048,00,1C
7562354,7582050,00,1C
7562348,7582052,00,1C
7562350,7582054,00,1C
Because Race...Convertible?
Turbo ZHP Convertible
Bali Im swapping trans next week. Up to a little coding?
Right but I dont think I can set it up on my laptop. Doesnt seem to forward the port correctly with windows on Mac
I was able to update the auto trans with winkfp daten 53.3 took about 2mins to flash and wow what an improvement. No more jerking coming to a stop even in manual mode(3rd-2nd), shifts are smoother. It's been a week of observing all is good.
Had a little problem when updating DME after updating trans. I was wondering if some files are not correct?? I updated winkfp using BMW coding tool to add the E46 files. Any advice pls.. Was using a battery charger with 10amps.
Bali, have you flashed EU2/EU3?
Edit: Did one google search. EU doesnt exist for MS45
Administrator
Discussion Starter · #94 · (Edited)
How to Update
I use the following steps to update a DME or EGS. It assumes you have BMW Standard Tools 2.12 installed correctly and have imported daten files into WinKFP.
  1. Put key in and turn to position 2 (run), but don't start the engine.
  2. Turn off all accessories.
  3. Connect INPA cable to car and laptop.
  4. Open WinKFP.
  5. Click "Comfort mode".
  6. Click "Update ZUSB" and you get a box displaying ECU families.
  7. Choose your specific ECU family, then click Ok.
    • MDS42 for MS42 DME
    • MDS43 for MS43 DME
    • MDS451 for MS45.1 DME
    • MSS54 for MSS54 DME
    • GD20 for GS20 EGS
    • GD8602 for GS8.60.2 EGS
    • GD8604 for GS8.60.4 EGS
    • SMG2 for SMG2 EGS
  8. Click "Done", which goes back a screen.
  9. Click "Prog ZB-Update", and you get a box that displays your current ECU version and suggests an update version, click "Yes".
  10. You get a box asking permission to program ECU, click Ok and the update begins.
  11. The update goes in two phases, first code then data, with a prompt before each phase begins. It takes about 10-15 minutes to complete for all ECUs, except about 45 minutes for MS45.1.
  12. At the end it tells you that the programming was okay.
  13. Turn key off, wait a few seconds, then turn key back to position 2.
  14. Using INPA or BMW Scanner 1.4
    • Reset all DME or EGS adaptations.
    • Clear any error codes in all CAN bus modules (DME, EGS or SMG, ABS, IKE).
  15. Try to start the car. If it doesn't start the first time, don't panic! Just clear any error codes in all CAN bus ECUs and try again. It sometimes takes a few crank attempt/clear error tries before all ECUs are happy.
You can see screen shots in this thread.
How to update your DME with WINKFP - CSL Register
Administrator
Discussion Starter · #95 · (Edited)
How to Flash a Specific ZUSB
There are cases where you want to specify the ZUSB (assembly) number to program, rather than letting WinKFP choose it for you.
Here are some common reasons:
  • You're flashing in EU2 software to turn off SAP and post-cat O2 sensor support.
  • You swapped a 330 engine into a 325 and need to flash 330 software.
  • You want to flash in different software to try it out.
The process for doing this in WinKFP is slightly different than doing a straight update to the latest ZUSB.
Follow the same process in the previous post, but replace steps #6 through #9 with these:
6. Click "Choose ZUSB" and you get a box displaying ECU families and their available ZUSB numbers.
7a. Choose your specific ECU family, choose the ZUSB number you want to program, then click Ok.
7b. Click "Enter VIN", paste or type in the car's entire VIN, then click Ok.
9. Click "Program", and the update begins.
Correct. I still run cats so it wouldn't even matter for me. Plus there's nothing to flash anyway for me
Sent from my XT1585 using Tapatalk
Administrator
Discussion Starter · #98 · (Edited)
How to Reset Adaptations
This describes how to clear/reset DME or EGS adaptations using INPA.
Be sure key is in position 2 with engine OFF.
MS43
  • E46
  • Engine
  • MS43
  • F4 Error
  • F7 Reset adaptions
  • F8 adaption Variants clearing
MS45.1
  • E46
  • Engine
  • MS45
  • F8 adaption
  • F9 All
GS20, GS8.60.2, GS8.60.4
  • E46
  • Transmission
  • GS20
  • F6 Activate
  • F3 Reset adaption values
Administrator
Discussion Starter · #100 ·
Bali any "eBay kit" you recommend that includes what I need?
I look at a few but don't know if it's the right ones as they seem to have different versions. Would this one work?
http://m.ebay.com/itm/INPA-Ediabas-...erface-Cable-for-BMW-/331458709628?nav=SEARCH
Yeah, that one looks correct. There are lots of vendors selling the exact same Chinese-made cable like that one. So just pick one that is cheap with free shipping from a location nearby.
You'll likely need to solder together pins 7 and 8 before you use it.
