601 - 620 of 723 Posts
Administrator
2004 330Ci 115k miles
Discussion Starter · #601 ·
Solve it by successfully completing the flash update. Try a different PC or cable.
Also, remove the BimmerGeeks installation as it is incomplete. Follow this guide to install.
Thank you for the quick response! I uninstalled the bimmergeeks software and am following your guide as we speak. I will update once done.
After following your guide to the T, and updating my K+DCan drivers, then following your installation guide the flashing completed without hiccups!
I reset the adaptions, cleared any fault codes and the car started on the first try.
Thank you so much for your guide and your help! Yours should be the defacto guide for everyone to follow.
Supercharged Titanium Silver 330ci
I just performed this reset and now my car runs bad, has a CEL, DSC, and Brake light on the dash.
MS45.1
  • E46
  • Engine
  • MS45
  • F8 adaption
  • F9 All
Running great now. That was scary. Reset appears to have cleared my rough acceleration after fixing a vacuum leak. Hope it lasts.
Administrator
Discussion Starter · #608 ·
EGS version history (GD8600.HIS)
; Zusbauhistorie fuer GD8600 vom 23.03.2000 07:28
;ZB-ALT ZB-NEU FREIKENNUNG
4307919,1423291,00,28
1423390,1423487,00,28
1423414,1423485,00,28
1423412,1423483,00,28
1423525,1423680,00,28
1423487,1423678,00,28
1423523,1423676,00,28
1423483,1423672,00,28
1423485,1423674,00,28
1423678,7504952,00,28
1423630,7506153,00,28
1423672,7506149,00,28
7504954,7506151,00,28
7506151,7507757,00,28
2000 323iT
Ok, I confirmed that your 04/2000 323i has the ZF auto trans with GS86.00.0 EGS.
Find your current assembly number using INPA, BMW Scanner 1.4, etc. and look it up in the version history above.
How to Check Current Version
EGS -> 01.04.00 WBAAR334XYJM01035 0 km 7.508.228 7.508.229 1.000.000 012321 42324 -
unless I am blind, I don't see it above, although I did find it here.
924469
Administrator
Discussion Starter · #612 ·
Yeah, it doesn’t look like an update is available there.
I don’t think I have ever found an update for the early GM or ZF transmissions on the 323 and 328.
BaliDawg, would you be able to help me set up INPA and/or WINKFP? I have a bimmergeeks cable and would like to reflash a 04 E46 DME back to stock with the latest stock tune. I'd be more than happy to make a donation to you and/or this site for the help. I didn't see a way to message you privately, I apologize if this is not the way to contact you.
//Binary is in my DNA
2002 BMW 325i
@1980kid Nice shot of Erich Joiner's GT3R in your profile pic! Love that car.
Administrator
Discussion Starter · #618 ·
Hi, yes I can set it up remotely, or you can just follow this guide.
I will PM you my contact info to schedule the update.
EDIT: PM sent.
When flashing the DME from 325 to 330, can you incorporate rear 02 delete and sai delete so it doesn't throw any codes?
Sent from my PH-1 using Tapatalk
