1 - 8 of 8 Posts
hey peeps.. does ne1 kno if 9006(hb3) bulbs can be used for the h7 bulb? b/c i got a 9006 bulb lying around n i hope to use it on my m3 high beam.. does ne1 kno if that could be used? or could my 9006 be used for fogs? thankx
I believe the high beam uses 9005 or H7, not 100% sure.
If you have one 9006 bulb "laying around" it might not be worth it to try to use it, esepcially if it's been poorly handled since you've had it. A poorly handled halogen bulb can burst while in operation.
Also, it's best to replace bulbs in pairs to they look the same.
no, a 9006 bulb will not work in your headlights b/c it requires H7 bulb, which is a completely different size bulb.
it will work in your fogs, which are 9006.
1 - 8 of 8 Posts
