That’s great news. Hopefully the sealant and tightening it further prevent any more oil leaks and you can get it on the road!
Yeah just read this earlier today. Will start it up tonight and see if it holds any better this time around, might try Permatex #2 if it's still no good.Did you see this thread?
Massive oil leak after rebuild (solved: oil gallery plug)
I treat it as a pipe plug. My hands tell me when it's enough. Sealant does the rest.www.e46fanatics.com
Cleaning the threads in block of all oil and the use of a good sealant seems critical.
MrMCar recommended Permatex Form-a-seal #2...non-hardening sealant.
Which one is that then?The type of sealant used should have been quite apparent on removal. If the fastener doesn't seat against anything and isn't a taper thread, it requires an anaerobic thread locker to lock and seal against the oil pressure. Loctite 242 is rated for 100% strength in motor oil at 125°C. I had to look how the preapplied stuff works. It contains micro capsules which burst on installation to release the chemicals which do the work. Loctite has a product specifically for this application.
Good stuff...Did you fully seat the gallery plug, or did you leave it flush(ish) to the surface?Ladies and gentlemen, we have a winner! Regular blue Loctite 243 looks to have done the trick. Ran the car for about a minute, no drips. Took the flywheel off and everything looks bone dry. Previously, it would start to pour out within seconds. Finally! Might actually take it for a drive this weekend.
Thanks team!
Oddly enough some of the loctite datasheets say the pre-applied stuff is reusable, I only looked at a few. Pre-applied is used to speed up assembly. Using liquids at home is just fine.Honestly only the engineers can probably tell you what sealant is used by BMW. All those "micro encapsulated" fasteners come from BMW with the sealant/thread locker already applied and are considered one time use for that reason. When you read BMW's repair instructions that's often a reason for replacing a fastener.
Loctite sets regardless if the fastener is torqued or not.Good stuff...Did you fully seat the gallery plug, or did you leave it flush(ish) to the surface?
My best guess without reading all of the datasheets is Dri 506. It's not something you can buy in a tube. The std blue you used will be every bit as good.Which one is that then?
Just about, maybe a mm in from the surface, definitely not all the way in.Good stuff...Did you fully seat the gallery plug, or did you leave it flush(ish) to the surface?
