Hi all,
I'm running around trying to diagnose my e46 325i touring manual with an overheating and disappearing coolant issue. Car has 205,000 miles.
In 2019 around 180,000 miles, I replaced the entire cooling system (hoses, sensors, thermostat, water pump, expansion tank, etc), bar the radiator. Everything was OE or OEM replacement. Car has been super solid since.
Recently at my oil change, the guys said coolant was low but they didn't have any more.
The next day I get some drive through food and pull out hard, revving to like 6k. I look down a mile or two later and my temp gauge is in the red. It was dark and raining so I finished the quarter/half mile back home and turned it off right away.
I've always vigilantly watched the gauge and never seen it move past dead center. I know I was supposed to pull over immediately, and I did so as soon as I could safely.
I refilled coolant and drive a few miles the next day and it overheated again. This time, I shut it off again as soon as I could. It hit the red and I got it towed home.
So, things I've done/noticed:
- Coolant refilled and system bled multiple times.
- Rented a cooling pressure test kit and it held 9psi no problem. No audible leaks or bubbles spotted.
- Unplugged lower radiator fan switch to trigger fan to be on full and it didn't help - still climbed past 110 Celsius
- No coolant in oil (recent oil change was 2 days before first overheat)
- Car will idle in the driveway for 20+ mins but eventually start to overheat. If I drive it, it'll overheat in like a mile or less.
- Seemingly no heat coming out even when engine is warm
- Noticed light white smoke coming from exhaust at idle and when revving, even when warm. Filmed a video of that here. It's hard to see, but you'll notice it for sure. E46 overheating and white smoke
My logical next steps I think are replace water pump and/or thermostat again, but I'm concerned by the white smoke.
Do I have a cracked head?
