Just posting this so I can keep track of where I've been and where I'm going...
Project List:
So far I have:
-Replaced old crappy broken and repaired stock shifter with gray glue gobbed all over it >>> bavauto lighted shift knob w/ black boot
-Removed old crappy bubbly purple tint from the rear window
-Replaced 5 broken door panel clips causing the driver's side door panel to be loose
-Replaced a broken right kidney grille
-Replaced inop wascherpumpe (original Deutsche spelling on the box lol)
-Replaced front control arms and bushings with Meyle
-Crawled under for a CDV delete and found it already deleted
-Replaced Secondary Air Pump (used)
-Replaced Differential oil (Royal Purple 75w90)
-Replaced Transmission fluid (Royal Purple Synchromax MTF)
-Replaced Front rotors (Zimmerman) / pads (Akebono)
-VCG/plugs/VANOS rebuild
-new Belts/pulleys
-replaced entire cooling system
-replaced both air filters
-replaced battery with Duralast 49DL from Autozone
-replaced windshield cowl
-replaced low beams - philips crystal vision ultra bright white
-replace lug nuts
-replaced wiper blade inserts
-removed aux fan, replaced mechanical fan with electric (Bosch)
-replaced driver's side seat belt tensioner and wiring harness
-replaced headlight covers
To do list (needed):
Rear trailing arm bushings
differential rubber mounts
Fuel filter
sway bar end links
brake fluid flush
oil level sensor
struts/shocks
To do list (wanted):
clutch stop
SSK
Hood dent and front bumper scrape repair/repaint, or facelift hood, or painted CF hood if I can find a used one cheap
Angel Eyes
HID's (possibly quads)
Better mirrors
lower her a bit
different bumpers
respray
Project List:
So far I have:
-new Belts/pulleys
-replace lug nuts
Fuel filter
sway bar end links
brake fluid flush
oil level sensor
struts/shocks
clutch stop
SSK
Angel Eyes
Better mirrors
lower her a bit
different bumpers
respray
