It is so nice to be back in this car! I'm remembering why this is my third one, it is such a joy to drive.
Yesterday I took care of the inspection and checked into a couple of minor issues. The RR suspension had a thumping over small bumps at lower speeds. I remember hearing this before, and was pretty sure I'd narrowed it down to the shock, especially since the mounts only have a few hundred miles on them. I pulled the left rear, double checked the mount and how tight it was to the shock, and all was well. Cycling the shock out of the car around ride height I could feel a little dead spot as the piston changed direction. Since they are Koni Yellows, I removed the mount a dialed up the damping about 1 full turn. So far the noise is less, but it's still there a little bit. I guess it's time to reach out to Koni about a warranty claim.
Today I took care of the alignment. I was reminded, again, what a pain the inner jam nuts on the ebay camber arms are to access. I think a 27mm crows foot would do the trick. Fortunately the camber wasn't really out of spec, and I was able to tweak the one side a little without releasing the inner nut. The rear overall wasn't far out, but a little less toe isn't a bad thing. I think the camber, despite being in spec, may still be a little too aggressive. The inner edges of the tires were wearing excessively, previously.
