That’s some next level preparedness, good on you. And good luck next week 👍🏻I'm not exactly sure which rodents deposited said acorns, but at least that's all they seem to have nibbled on.
This morning I had a bit of extra time before a dentist appointment so I stopped by the inspection station to check over the paperwork before my inspection next week. Everything looks good, so everything should go smoothly next week.
Bummer about the leak. I wish you luck in sorting it easily.This weather is not conducive to stripping window tint. And to top it all off the front passenger floor is wet after having rain Tuesday into Wednesday. Grrr.
I'm figuring it's probably the sunroof drain. The car was either covered, or parked in a way that the RF drain would be last to see water before. As it was parked at the shop doing the enhanced inspection it was likely the first. Either a result of the airbag deployment, or perhaps something I disrupted while replacing the airbag. These are the reasons I did not put the new A pillar screw covers in yet!Bummer about the leak. I wish you luck in sorting it easily.
Can the drain tube become disconnected? I can't recall if it was an E46 or the LR3 I used to have, but I recall the plastic / rubber tube coming away from the metal tube for the drain - near the sunroof.I'm figuring it's probably the sunroof drain. The car was either covered, or parked in a way that the RF drain would be last to see water before. As it was parked at the shop doing the enhanced inspection it was likely the first. Either a result of the airbag deployment, or perhaps something I disrupted while replacing the airbag. These are the reasons I did not put the new A pillar screw covers in yet!
Yes, they can. My 2001 had the RF disconnected and I never knew it until I parked the car with the front pointing downhill and it rained. Lake E46 in the RF footwell.Can the drain tube become disconnected? I can't recall if it was an E46 or the LR3 I used to have, but I recall the plastic / rubber tube coming away from the metal tube for the drain - near the sunroof.
I have such a love hate relationship with sunroofs. Since earlier this summer when YJsaabman mentioned all the extra (distracting) light that comes through when the shade is open, I can’t not be bothered by it anymore! I still enjoy some hole in the roof days in the shoulder seasons though… heated seat at iii and the sunroof open… chef’s kiss!Can the drain tube become disconnected? I can't recall if it was an E46 or the LR3 I used to have, but I recall the plastic / rubber tube coming away from the metal tube for the drain - near the sunroof.
