201 - 220 of 261 Posts
Premium Member
2003 330cic, 2003 325iT
Discussion Starter · #201 ·
Wrist pin.
the cylinder that connects the piston to the connecting rod.
It has three points of contact, two at the piston and one at the rod. I would presume that if I replace the pin I should replace and hone all three bearings, no?
I am not referring to the rod bearings at the crankshaft.
Premium Member
Piston is sans bearing. Tantamount to the camshaft ledges.
Premium Member
Discussion Starter · #210 ·
Trying to find a replacement wrist pin. In the meantime, doing some cleanup on the existing pistons:
932832
The head should be done next week, and a whole load of parts from FCP came yesterday - head bolts, rod bearing bolts, head gasket, rod bearing shells, stem seals. Got m52tu rings and Meyle m54 rings that I am going to make mixed sets out of.
932839
Will rebuild as soon as I have an answer to piston 2 and its wrist pin.
2001 325i Touring. 5-speed manual. Formerly automatic.
Oil pump is refreshed. Removed the pressure regulator, cleaned and changed the o-ring:
Since you’re on the oil pump. How do you feel about safety wiring the oil pump nut?
I’m about to go 5-speeds and replace the oil pan gasket in the process so I figured I might as well get at that oil pump nut and safety wire it.
While I’m in there what else would you recommend I should replace as preventative maintenance aside from the rear main seal and associated housing gasket, engine mounts and LCAs?
Super Moderator
'03 325iT Mystic Blau
Steering guibo for sure.
Premium Member
Discussion Starter · #214 ·
While I’m in there what else would you recommend I should replace as preventative maintenance aside from the rear main seal and associated housing gasket, engine mounts, and LCAs?
Giubo, high-pressure PS line
I did use a wired pump nut (not visible in the picture)
Reminding me of all the lightly used parts I have in my basement that I need to install when doing my swap! Still hoping with good prep I can knock it out in a 3 day weekend. Manual to manual and already MS45.1 should help.
Sent from my SM-G970U using Tapatalk
Premium Member
Discussion Starter · #218 ·
Big day. Valve cover is cleaned up and ready for install
933350
Need to find some time to gauge the rest of the oil rings and see what is up. @Effduration 's Timesert kit showed up yesterday, so there is that to look forward to!
Premium Member
Discussion Starter · #219 ·
Timeserting. Thanks to @Effduration for the tools. Though I am waiting on a 1/2" tap handle from Amazon.
933544
