1 - 2 of 2 Posts
Party Times!
When i go to turn on my lights (first setting) only my corners illuminate, and when i turn on any other thing the xenons come on, i cannot get the middle lights (daytime lights?) to come on.
In Pursuit of My J.D.
You have to get the Daytime Running Lights (DRLs) turned on by your dealer. They're the inside lights, which also act as your high beams (flash to pass.) In order to turn on the inside lights, you have the pull the left stalk towards you, which flashes the lights. If you have a 2002 model w/ Xenons, then you have to push that same stalk forward to get it to keep your high beams on (which will be your Bi-Xenons.) I hope this helps and answers your question. :thumbup:
1 - 2 of 2 Posts
