If the roads in your area are good, - go for it! Otherwise, it will be a teeth grinding. I live in Chicago area, where the roads are the worst in the nation, so the ride is pretty harsh. The car' drop looks awsesome though. When lowered all the way, there is no gap between the 18" (wheel+tire) and the fender
impin: At the same time, the wheel still not tucked under the fender.
I just raised the car all the way (~1.5inch) for winter and swapped for 17" winter wheels+tires. The ride became more comfortable but still stiff.
So if you don't care about raising and lowering, the much cheaper and still good looking drop would be H&R sports springs only, instead of expensive H&R coilovers
