1 - 20 of 29 Posts
Mtech II Brackets/Air Ducts on Facelift ...Which Brackets?Vendor?
Ok so I need to buy the Mtech II front and rear bumpers, My car is in the shop waiting. Ive been searching the forum all over for this info and found some but i just want to clarify it .... If I buy the Mtech II kit for my facelifted sedan (2002) Im going to have to buy new brake ducts and brackets (left, center, and right) as well as new bumper brackets (prefacelift) to make the Mtech II fit on my 02 sedan. correct? i believe so.
Here is where i am confused ... i have called around to some of the vendors DDM,Eurodyne .. and they have confirmed if I buy their bumpers i will need to do that. However someone told me if I buy from Euro-spec/ DTM-Spec I wont need to buy the prefacelift brackets for their MtechII bumper, and that it will bolt right up is this true?
Edit/Update
Thanks for helping me out fellas :thanks: I put it all together for those who need it in the future. Its all here facelifted sedan with mtech II kit front and rear (bought from Jo @ euro-dyne)
FRONT BUMPER
Bumper Support Bracket
51-11-7-895-415
51-11-7-895-416
Air Ducts (Air Ducts are not necessary for the install but will complete the overall look and completeness of the new bumpers.)
51-71-7-894-699 Left
51-71-7-894-700 Right
Air Duct Brackets (Air Ducts are not necessary for the install but will complete the overall look and completeness of the new bumpers.)
51-71-7-894-721 Left
51-71-7-894-722 Right
Center Duct
51-71-7-894-821
51-11-8-195-304 Center Molding Strip w/o license plate holder (Only necessary if you want to delete the euro license plate holder that comes with the bumper)
REAR BUMPER
51 12 8 195 321 Fender Left
51 12 8 195 322 Fender Right
http://www.realoem.com/bmw/showparts.do?model=ET37&mospid=47720&btnr=51_3275&hg=51&fg=75
http://www.realoem.com/bmw/showparts.do?model=EV53&mospid=47725&btnr=51_4543&hg=51&fg=15
You will need new brackets, unless you have an Mtech I front bumper on your car., also will need brake air ducts.
Discussion Starter · #3 ·
Is this true even if i buy from Euro-spec? I would ask them but their overseas and its hard to get a hold of them this week. Considering im kind of in a hurry i cant really wait until next week just to ask them the Q
Discussion Starter · #6 ·
you will need brackets no matter where you get your Mtech II or M3 bumper from .
I actually had an M3 rep bumper on before ... does that mean i can just use those brackets for the Mtech II? The only thing i never did when I got the M3 Bumper was change the air ducts...
you should be just fine with those brackets. Those are the exact same brackets. All you will need is the ducts if you want them. I got my Mtech Installed recently and I didnt get the ducts for it. I will get them down the road, but no big deal at the time.
SUPPORT FENDER LEFT X1 #51118195295 $4.02
SUPPORT FENDER RIGHT X1 #51118195296 $4.02
HEX BOLT X4 #07119901509 $0.30
FLAT WASHER X4 #07119936441 $0.45
these are the ones i need to installed them to my facelifted sedan w/o mtech1 bumper? fosho?
do I need these as well ?
51-11-8-174-185 EXPANDING RIVET (x20)
51-11-8-222-901 BLIND RIVET (x8)
51-11-8-191-149 GASKET
You don't really need the air ducts if you don't have the cash. I had part of one fall out and if I recall correctly, they're kind of expensive. 2 parts to each side x 2 sides = $150 or so.
i have a 2003 325i facelifted sedan, will all the part numbers be the same if i get the m-tech 2 from euro-spec / dtm-spec?
Discussion Starter · #14 ·
yup
Discussion Starter · #15 ·
he speaks the truth
however, it makes it look complete
Discussion Starter · #17 ·
NO all air ducts are preference. The only drawback may be when youre truly pushin your car hard and can use that extra bit of airflow or if someone is up close to your ride and can see how the ducts may be uneven (if you dont switch them out). Some people choose not to spend the extra 150 bucks or so. I on the other hand did it the first time around.
51-11-7-895-415
51-11-7-895-416
Are these pre-facelift Part #'s the same for a COUPE?
I have a facelift Coupe and I'd like to install the MtechII front bumper on. Do I need any other mounting small parts (bumper guides, expanding rivets, etc?)
What about the Altenator duct? For a complete install wont you need that as well? Or does the original one work?
Also from the little research I have completed thus far all those with XIs will have to get a different part number for some of the ducting. Brake Ducts for sure. Not sure about the other ducting at this point.
1 - 20 of 29 Posts
