@sda2 - First, thanks for all you and the other dev's have done! Really appreciate it!
What car do you have?
- 2001 e46 325i MS43
Any modifications done to the car? (engine, gearbox, cluster swapped, removed immo module, etc.)
No modifications
What is the actual problem, what doesnt work?
Car doesn't start after upgrading to MS430069.
What have you tried so far?
1. Patched the MS430069 bin with Immobilizer Bypass, Checksum ByPass, and launch control using the Community Patch list and moved my VIN over.
2. Tried a clean copy of MS430069 and just copied my VIN over.
3. Tried flashing back to my original dump, but it seems that I didn't correctly read it because that didn't work either :/
4. Finally tried MS430056_Logger_EWSsignature_CHK5off_LC.bin with my VIN and it started up just fine.
Was the engine already tuned, or flashed with another software?
No.
If errors are present please attach pictures of all INPA error codes from DME.
Also attach full 512K readout of the ecu when the error is present.
I don't have these right now. But the one code I kept seeing was an EWS-Code error. I can try this again and get you the full data.
I wouldn't mind getting to MS430069 (maybe with EWS enabled? I don't know much about that). What should I try and what would you need from me?
No modifications
No.
