After a full read and saving my original DME bin file for my 325i and realizing I was on the 0066 bin, I decided to update. I've been learning and researching how to use MS4X Flasher for my upcoming M54B25 to B30 swap and felt like I understood what I was doing, but on the first attempt to flash the MS430069 bin file for US that I downloaded from MS4X.net, I got an error code toward the end of the flash telling me it failed. I then noticed that I had actually used the MS430069 bin for the B30, so I was going to re-flash anyway, but when I tried to flash again, I got a safety check error that I'm pretty sure was due to the failed flash.
After a slight panic hit me, I reset the computer, turned the car off, checked my battery charger status and tried to start the car - crank, no start. Not surprising.
Instead of forging ahead with trying to flash the 0069 bin again, I decided to write my original bin file back to the DME, which required me to turn off the Safety Check in MS4X Flasher and was a nervous few minutes waiting for it to complete, but I'm back up and running again.
Before I take another stab at this, I just wanted to double check with someone who knows this better than me that I'm doing this correctly.
In MS4X Flasher, load Siemens_MS43_MS430069_E46_M54B25_US.bin and do a full write. Once completed, turn the car off for 10 seconds.
If successful, then do a full read, save that bin, then I can make changes in TunerPro and save as noting what I changed.
Do I have this right? TIA
