1 - 3 of 3 Posts
I have a MS43 swapped 2000 touring with a b30+manual trans. Been trying to figure out why the throttle pedal was not working.
I am using the MS43 engine harness. I have wired the 6 pins to the dme and checked that they are in the correct spot.
Tried with MAF plugged in and not and recalibrating it.Throttle body itself works because it does a little blip when the car starts.
Not sure what to do. Either i need to grab a different pedal from the yard or reset throttle body using inpa.
Am i missing anything?
Discussion Starter · #3 ·
Trying to get cable to work. Came across a thread with a guy who had clogged cats and his pedal wasn’t responding. I am not running my downstream o2 sensors and have not gotten the dme coded for this. Could this be an issue? If so what code should i look for?
1 - 3 of 3 Posts
