1 - 5 of 5 Posts
Hi
I have an airbag light on in my 2000 E46. I have plugged in my laptop to try and read the fault code to understand which sensor might be at fault, but can never connect to the airbag ECU. When using INPA I get no response from control unit as an error (see copy and paste of the error readout message I get below). When I use EDIABAS I get a similar response along the lines of not being able to connect with the ECU.
Am I missing some files needed to 'talk' to the relevant other components of the car? if so any ideas where I can get the files?
Kurz***8319;bersicht der SGs, die auf IDENT geantwortet haben:
ECU/group answered Notation
KOMBI46 yes Instrument cluster
IHKA46_2 yes Air conditioning
LSZ yes Light switch cluster
MS430DS0 yes Motor
RADIO yes All radio type except MOST-vehicles
PDCACT yes Park Distance Control ACT
SM46_3 yes Seat modul oder Easy Entry Driver
EWS3 yes Vehicle immobilization / Electronic vehicle immobilization EWS
ZKE5 yes Central body electronics
D_00A4 * Airbag ECU or Safety Info Module
### IFH-0009: NO RESPONSE FROM CONTROLUNIT
D_009C * Convertible top module
D_0076 * CD-Changer I-Bus
### SYS-0008: JOB NOT FOUND
D_ABSKWP * Dynamic stability control
D_0065 * Electronic fuel pump
D_0032 * Gear box ecu
D_0048 * Japan Bit
D_0057 * Steering angle sensor
D_009A * Headlight level control
### SYS-0012: IDENTIFICATION ERROR
D_0066 * Light / Active Light Control
D_XEN_L * Light Xenon left
D_XEN_R * Light Xenon right
D_00F0 * Monitor
D_00BB * Navigation system Japan
D_007F * navigation computer
D_00E8 * Rain- light sensor
D_0070 * Tyre pressure control
D_SZM * Middle console center switch
D_00DA * Seat modul oder Easy Entry Passenger
D_00C8 * Telefon or Universel loading- and handsfree set
D_009E * Overrollsensor
D_00ED * Videomodule
D_003B * Videomodule graphic part
D_ZUHEIZ * Auxiliariy heater
### IFH-0004: ERROR IN INTERFACE COMMAND
// Quandt AG (Retired) //
Discussion Starter #3
Thanks for those files. I have managed to get most things working just the drivers for the OBD cable don't work. I'm running Windows 7 32bit. Do you have any way of installing the drivers for the cable?
1 - 5 of 5 Posts
