I have a 2004 325xi, M54 2.5L.
I'm having an intermittent misfire on cylinder 3 with SES light. This misfire only occurs when driving uphill. If I shut the car off and turn it back on the SES light goes away and the car will run fine. Even if I drive uphill it might run fine, other times it might not.
So far I've changed all spark plugs and the coil in cylinder 3. Also put a new valve cover gasket and DISA valve on. Ran compression test in all cylinders and got these.
Anyone have suggestions on what to look for next and how to fix?
- 135
- 140
- 140
- 139
- 140
- 120
