Hi all, new to forum but have found loads of help from lurking and reading past posts to fix my BMW.
Little bit of background on my car: Have a 2002 330ci manual, about 125k mi and as far as I can tell is pretty much original everything (except what I have done to it) brake buster vacuum whistle and all.
Recently it has formed a new bad habit. A number of the cylinders cut out while idling and sometimes driving. Car sounds awful, but does still run (kinda) as soon as you turn it off and back on it runs just fine until it does it again at a random time. Plugged it in to my little PA soft and got a page off error codes picture is attached, I think. It seems there are O2 sensor codes along with a misfire on every single cylinder and a misfire with cylinder cutout on 1,2,3, and 6, and running rich.
Not sure how to address this new issue but a number of the things that have been done to the car are:
ABS control unit rebuild (still does not work)
shocks and struts
suspension bushing
brakes
power staring rack (steering angle code ever present)
disa valve repair
spark plugs
crank case vent valve replacement
full fluid flush
motor mounts
fuel filter
new battery
a couple tanks with injector cleaner
Runs exclusively on premium (ouch)
Any advise is helpful. Thanks!
shocks and struts
suspension bushing
brakes
disa valve repair
spark plugs
full fluid flush
motor mounts
fuel filter
new battery
