Well done!Fun fact i'm dealing with the exact same leak location as you, infact i'm doing my oil pan today on my Xi. When i removed my RMS, the back of my oil pan gasket was coming apart in chunks. It appears RTV did not help.
Just for fun and educational purposes take a look at this time stamp
Obviously one should not bolt up the tranny with a hole on the block like this, and how many times he removed the tranny to check the oil seal leaking?. There are no ant-holes on a metal engine.Note to self. Verify that plug is in place four times before meeting up the transmission.
You are correct, but I’ll bet this isn’t the first time it’s happened. That and many other things that can go wrong building an engine. Obviously experience and attention to detail goes along way.Obviously one should not bolt up the tranny with a hole on the block like this, and how many times he removed the tranny to check the oil seal leaking?. There are no ant-holes on a metal engine.
I didn't watch it all.Well done!
