I would just take off the door card and remove the speaker grill to paint away from the car.
Thx for replying Paraklas,Wipe with alcohol
I have removed the door cards , Its the application of masking tape that's the problem...I would just take off the door card and remove the speaker grill to paint away from the car.
this is the only solution to avoid a mess.I would just take off the door card and remove the speaker grill to paint away from the car.
disassemble the plastic parts to paintI have removed the door cards , Its the application of masking tape that's the problem...
Hi resunoiz ,disassemble the plastic parts to paint![]()
That's a shame as according to everyone else it's all about drilling off the heads of the plastic rivets and re attach using screws and washers....unfortunately, no specific vid. I remember I removed less than 4 screw each side then it popped up![]()
mine had torx screw, 2000 320ci conv. but maybe not all the same.That's a shame as according to everyone else it's all about drilling off the heads of the plastic rivets and re attach using screws and washers....
Just bough 3 new rolls of tape, Scotchbrite multi surface ( blue ), 1 day only heavy duty ( yellow ) and aluminium tape..... ALL failed..tape does stick to it, it probably wasnt sticking because you had just sprayed/cleaned the area. i literally masked off the leather and sprayed the plastics a few weeks ago. give it another go mate
That is f'ing niceeeeeeeeeeee.I painted mine to look like it was 2 tone rather than all gray
