Hi everyone,
I'm looking for advice on a repair situation with my friend's 200k mile 2003 325i which has been showing its age with some serious issues lately. Here's the situation:
The vehicle developed oil leaks from the oil pan and valve cover gaskets due to age. On top of that, the water pump failed. This caused the engine to overheat, making the oil leaks worse and eventually causing the vehicle to run low on oil. Because of this, the VANOS gear solenoid and the timing chain also failed. After an inspection, the mechanic said the engine itself seems fine, but they recommend replacing the coolant pump, timing chain, valve cover, oil pan, and doing an oil change. They quoted $11,600, but they offered to bring it down to $9,800. If decide not to repair it, they’re only offering me $250 to take it off our hands.
My main concerns are:
- Is this a reasonable cost for the recommended repairs?
- Should I consider selling the vehicle as-is and getting something else, or would this repair extend the vehicle’s life enough to justify the cost?
- Are there any alternatives to consider, like focusing on essential repairs or finding ways to reduce costs?
- Is it difficult if we do our own repair?
