Hi All,
I have been suffering from power loss for a while - i put my foot down and its like driving a slug and expecting acceleration... I have been reading a lot on this problem as many 3.18i owners seem to have it. One of my major suspects is the MAF after trying/replacing some other things.. so within the last hour i have just done the following:
1. Tried disconnecting the MAF while the engine is running expecting it to stay running (according to what i have read) but it cut out - this isn't right for starters is it?
2. restarted the car without the MAF connected and is started fine so i went for a drive. IMMEDIATELY, i noticed the power difference it was all a little jerky at first but i put my foot down and the car flew through the first couple of gears... to the point where your stomach turns not expecting to go that fast (if you know what i mean).
3. Drove for about half a mile like that then i noticed that the auto changing was getting rather heavy and it would THUMP going down into first gear. I didn't like that, it was actually a bit worrying so i stopped the car and plugged the MAF back in. (Why would the gear shifting change like that without the MAF? ) - With the MAF back in the car went straight back to normal, sluggish but absolutely no thump in the gear change... phew!!
4. Got back home and cleaned the MAF with contact cleaner put it back on but it made NO noticeable difference.
5. While the engine was running i unplugged the MAF again but this time NO cutting out, the engine just seemed to adjust a little.
6. I left it unplugged and drove it like this one last time and sure enough the power was back again!... not smooth but definitely back. The clunky gear changing wasn't there but i only went around the block a couple of times.
One las thing;
7. just remembered is it normal to unplug the MAF and have the dash light turn on next to the 'P' (park) that looks like an orange cog with an exclamation mark in it? according to the manual its an Automatic Transmission fault light causing the transmission to switch to the emergency-run program??
After all my research on the net and this result makes me confident that part of my problem is definitely a faulty MAF. Some of what happened i didn't expect but you guys have much more experience I'm sure, so please give me your thoughts?
much appreciated
Jason
One las thing;
much appreciated
Jason
