M54B30 turbo build
2.3K views 3 replies 2 participants last post by  Effduration
#1 ·
wassup guys I am in the process of doing my 1st turbo build bought a b30, have my 325 parked outside waiting for surgery, my main questions are about HEAD studs there only one video on youtube that i found about m12 head studs , has anyone here drilled their engine for m12 studs , what should i tell the machine shop? any extra advise is appreciated as well
#2 ·
M12 drill /tap is pretty large for this engine.. I have seen M11 threads tapped...once.
Your best bet is to install steel M10 x1.5 time-serts ..22.5mm in length and use ARP studs of same thread.
Use time-sert kit 1090 to install the time-serts in a B30...It has a drilling/ tapping jig specific to the B30.
You COULD use the Big-sert M10x1.5x22.5 in the B30, but I only install Big-serts when a regular time-sert fails - almost never unless installed incorrectly. I think Big-serts are overkill in your application.
The Big-sert kit is Time-sert 1090BS
#3 ·
M12 drill /tap is pretty large for this engine.. I have seen M11 threads tapped...once. Your best bet is to install steel M10 x1.5 time-serts ..22.5mm in length and use ARP studs of same thread. Use time-sert kit 1090 to install the time-serts in a B30...It has a drilling/ tapping jig specific to the B30. You COULD use the Big-sert M10x1.5x22.5 in the B30, but I only install Big-serts when a regular time-sert fails - almost never unless installed incorrectly. I think Big-serts are overkill in your application. The Big-sert kit is Time-sert 1090BS
I aiming for above 10 pounds of boost would the big sert kit still be overkill?
#4 ·
I'll let others opine on that, I don't have direct experience with a boosted M54...Although I don't recall reading about any boosted M54 failing with regular time-serts and studs installed.
Big-serts are stronger than regular time-serts, although you need to remove more material from the block to install Big-serts, potentially weakening the block ..For that reason, I only use them as needed.
  • Like
Reactions: princejzx100
