Thanks for the flow charts. Now they bring up a couple of questions. Sorry if these are obvious, but i'm new to this BMW engine.
I'm using a simple but large aftermarket radiator with only basic in and out hose ports. Can I eliminate or block the hoses as shown in my attachment? Will this cause any problems with coolant flow?
Radiator i have is a side tank cross flow radiator - like OEM. It is different in that the ports are reversed in position. Intake from thermostat housing is on passenger side like OEM, but low on radiator. Output to thermostat housing is on driver side but high on radiator. I can make up hoses that work. OEM is opposite with coolant input high on radiator and output low on radiator. Do you think there is any problem having the coolant flow across and up through the radiator and tanks, with gravity fighting the flow?
