I have a m54b25 na-t making around 400 crank. I am pairing this to an Getrag 420g which I just picked up and I need to order a clutch and flywheel. I know the 420g uses a different spline than the 250g that originally comes one the m54. I am thinking to use the m54 flywheel and pressure plate, and pair them with an s54/420g clutch.
I know that the 420g bolts up to the m54 so that is not an issue.
Will this work?
Are the disks the same size, even though the 420g input shaft is different?
Can I just use an s54 flywheel and clutch?
Does the M flywheel mate up to the m54 motor?
Will this work?
