Hey All,
Have a 2004 330i @ 159500 miles. Picked it up as a secondary daily and its slowly become a HPDE car.
Looking for some thoughts on addressing a rough start the car is experiencing. Started about spring last year and we've been monitoring, replacing/upgrading parts while doing other projects figuring it would either 1) resolve or 2) get worse and throw codes and be more noticeable. Neither has happened, haha.
Sometimes, the car has to crank for a second or 2 before lumbering to life. No codes thrown. No CEL. The starter is cranking, but the engine doesn't grab. When it finally starts it sometimes idles unhappy. Distinctive smell of gas from the extra sprayed in during crank. If the idle is bad (engine maybe misfiring?), blipping throttle seems to settle it back at 600-700rpm idle and while running, the car is totally fine. Good power, holds revs easily, no indications of misfire...
Other times (or immediately after), the car starts up immediately. From our testing, it happens either warm or cold. We have not found a deterministic way to replicate the issue.
All things replaced/addressed on the car in my ownership:
Fuel pump (This was done with a new VDO unit prior to the problem starting. Rest of list was done AFTER problem started)
Fuel filter & regulator
Pulled the manifold as a winter project and did all the complementary work:
new Ccv, replaced all the vacuum lines, intake boots, checked the DISA (replaced its O ring), injectors were cleaned and tested, ICV & TB cleaned, new gaskets throughout
Spark plugs
oil pan baffle & VAC pump upgrade
I thought maybe there's some vacuum leak, but my additive trims look ok?
Battery is newer and its charge isn't the issue.
That leaves me to MAF slowly dying, but the car distinctly falls to closed loop if I pull its plug.
Looking for thoughts on next steps for testing of if there's something I'm clearly missing at this point. Kinda exhausted all 3 parts....air....spark...fuel.
Was gonna hook up a KCAN & INPA but not exactly sure what live data to try and read to address.
Spark plugs
