1 - 7 of 7 Posts
Hello, I encountered a problem with my e46. There is annoying screeching noise coming near DISA. I took out and checked DISA few months ago, it seemed alright. I don't wanna speculate here so I will leave a video with that noise and perhaps somebody had exact same issue and knows the solution.
Also, there is an error I am getting from INPA. I'm not sure if these two connected, but would love to solve it too. Rough idle until engine gets warm. ICV is fine, MAF sensor is fine, no air leaks.
screeching noise -
INPA error -
913385
Administrator
The trouble code seems to be for the SAP system.
95DME: Activation, secondary-air valve (EUIII code: P0412)bms46ds1Motor Electronics
Using Google Translate, Ansteuerung Ventil Sekundaerluft becomes Secondary air valve control.
Use a mechanic’s stethoscope to isolate the noise source.
Premium Member
Sure sounds like air sucking or escaping.
Q: Pulling the dipstick out while running does what? If it goes away, likely a vacuum leak.
Discussion Starter · #4 ·
The problem is that the screeching sound occurs sometimes, so if it was an air leak, shouldn't it occur everytime? For example, I wanted to do your test and there was no screeching noise so yeah, I couldn't figure it out.
Discussion Starter · #5 ·
I found out that my secondary valve is dirty and whole hose coming from air pump too. Should I clean it or get a new valve? And what makes valve dirty?
Looks like sucking air somewhere.
Inpa error says
149 Air Flow Sensor or Pedal Value Sensor Mismatch
but this is normal if there is vac leak...
simillar situation to me:
It was sucking jet pump in my case along with the fuel tank breather valve.
as i see on the video some tubes are rapaired with a tape...will be ok to replace them.
Also, do a “smoke test”...
Discussion Starter · #7 ·
Inpa error says
Yup, ure correct my dude. Will do, thanks!
1 - 7 of 7 Posts
