41 - 60 of 82 Posts
Discussion Starter · #42 ·
so the new ARH are installed, custom piece being made to mate up to BW 3.5 more pictures soon.
906150
Discussion Starter · #44 · (Edited)
906705
906706
906707
906708
906709
ARH to HHR 3.5 Section 1 (Hanks Hot Rods), BW 3.5 Straight Pipe Section 2, BW 3.5 Diffuser Exit Muffler. Damn right, its better than yours.
Discussion Starter · #46 ·
Since I'm getting really close on finishing the s54 reswap. I bought an e30 for a n54 swap. YEE!
909624
Discussion Starter · #47 ·
915189
915190
915193
915194
915195
So headlights/headlight trim installed, spal fan with massive fan mounts, fuel filter/cover installed, vacuum line and fuel rail line installed.
Discussion Starter · #52 ·
915967
915968
New sways with adjustable links?! YUP.. Hotchkis sways, BW adjustable front links.
Discussion Starter · #54 ·
919154
919157
919158
Adjustable rear arms, they prevent premature tire failure and wear issues.
Discussion Starter · #55 ·
So a bit of a delay on showing the sway bars installed.. came across the same issue in the front and rear. Clearance... On a m3 you have no spare tire well, on a non m you do. The oem m3 rear sway bar will clear the spare tire well. The upgraded thicker bars will not fit and hit the spare tire well. Took my hammer, pry bar, and a 2x4 to make room.
919204
919205
Discussion Starter · #56 ·
Front sways installed.. Had to replace some old brake line/wheel speed sensor brackets, with new ones to gain clearance for the thicker adjustable front sway bar links.
919518
919519
919520
919521
Oowee! That Bimmerworld exhaust!
919656
Wish I had this kind of time with my swap, I only had a week to do a refresh and drop it in.
41 - 60 of 82 Posts
