M3 oil pan bolts
1 reading
2.2K views 2 replies 2 participants last post by  kj99
#1 ·
I am having a hard time finding specific information on the oil pan bolts. I literally had two bolts fall out on my oil pan. I put in a new clutch last year, about 2k miles ago. At the time it was spotless on the bottom of the motor. I had a small rear main seal leak and the constant pressure valve was leaking a little bit. I replaced both at the time. Recently I had the timing chain tensioner gasket fail and replaced that. In the last couple weeks I started to see a little oil on the ground and finally got it up in the air yesterday and I find that I had a oil pan bolt missing. It was in the plastic shield and I went to put it back in and noticed a second bolt was also missing. It was not in the shield. I am hoping I can put the bolts back in and it will stop the leak. I don't really want to replace the oil pan gasket right now if I don't have to. Realoem shows that there are a couple of different bolts, M6X20 and M6X25, but they don't tell you where the three M6X25 are located. The two missing are the front two on the drivers side. I am guessing they are both M6X20, but since I didn't take them out I don't know for sure if one of them is supposed to be an M6X25. There is lots of information on the oil pan bolts, but I can't seem to find anyone talking about which bolts are which. Probably because everyone just takes note of them when they take them out. Can anyone verify that the front two bolts on the drivers side are M6X20?
