Hey all,
Its starting to get cold here in Memphis, we got our first frost a couple of days ago. After the first frost, on my drive down to Starbucks the low coolant warning light came on. This was the first time I had actually powered up the heater to full since owning the car. As I don't have an ice scraper I left the car running with the defroster on full and the heat at 80 degrees for about 10 minutes before my Starbucks run. Anyways about halfway to Starbucks the light came on, however, just as I was pulling into Starbucks it went out. On my drives around town Saturday I monitored engine temps carefully and they never exceeded the midpoint on the temp gauge. And yet the low coolant warning flickered on and off all day long.
I checked the coolant levels several times, once when the engine was fairly-warm and once when the engine was cold and the results were the same, coolant levels were normal.
I decided to run some tests and I took the car out this morning with the engine completely cold (it had been sitting overnight) but did NOT turn on the heat. The result: No low coolant warning light. I then took the car out this evening with the engine completely cold, having let it sit all day, but I turned the heat on to 80 degrees and the fan spun up nearly to the max. I did the exact same route as I had that morning and the result: about halfway through the low coolant warning light came on.
So from this informal test, it seems like this is some issue with the heating system...any ideas on how I can fix it? I'd rather not be freaked out by this low coolant warning light coming on all the time or worse yet become desensitized to it and ignore when I really do have low coolant! :eeps:
Any help is appreciated! :thumbup:
