We also have magnetic drain plugs for your BMW. Featuring a permanently mounted magnet that traps ferrous metal suspended in you oil. These magnetic drain plugs trap tiny particles are unable to be caught by your oil filter, leaving you with a cleaner engine, and overtime saving your bearings and oil pump from unneeded wear.
Our magnetic drain plugs also capture many metal particles from rebuilt engines.
* The constant flaking effect of normal wear of reciprocating parts.
* Material missed after boring or machining.
* Small component breakdown caused by high RPM break-in.
Available with aluminum & copper sealing washers.
Best,
Joe
