1 - 7 of 7 Posts
Guys i had these 12 mm spacers on the rear, on my to work i notice the car handling funny with a noise coming from the rear i pull over to check and notice my tire was coming off i give the bolts a few turns then proceeded to work, however i jack the car up took the wheel off and notice that the 12mm spacers that i bought from vortextuning lip had broken off i was shock , luckything they were not on the front, now i need the best spacers for the front which is the best guys.
That happened to some cheapies i had once, I was just testing the size for a week or so and when I took them off...
:facepalm:
I have these on all 4 corners for about 5 months. pleased so far!
had a set of these once also, for over 2 years and they were used when I got them...
no problems either
lastly Turner is good also: None of these are in the "Cheap" category, but they are in the "will keep you safe" category!
Dang that sucks OP. good thing no serious damage to your ride. and your ok!
on another note whats a good size for stock style 68's?? I think they would look alot better with a wider stance.
1 - 7 of 7 Posts
