Looking to cure my endless oil consumption. M54 with likely worn or sticky oil control rings, 103k miles. Already rebuilt and swapped an M56 valve cover. No luck. Considering reverting to the stock cold climate CCV with the 02Pilot mod since an engine rebuild isn't feasible right now and likely won't be for a few years. There's some speculation as to whether extra negative pressure in the crankcase would suck seals in and cause a tricky to find vacuum leak. I've replaced all the gaskets (front and rear main, oil pan, oil filter housing, valve cover, etc...) on the motor, but I don't want to play chicken with them. Looking to get some feedback from everybody; how long have you ran the 02Pilot mod and have you encountered or heard of any negative impacts from using it long term? I'd imagine there should be no problems, since other manufacturers install only a PCV valve on their engines and put their crankcase under negative pressure.
