Status
Not open for further replies.
lignts do not flash when Lock/Unlock
19K views 12 replies 7 participants last post by  MakeItWorkNow
#1 ·
Hi guys,
So I am now on board of the coding/programming. After about 1 month reading and a solid IT background, I have coded the first nice things into my E46 318i (08.2000). However, I wanted to enable the blinkers (corner lights or however you call them) to blink when I lock and unlock the car. Before the operation, they were blinking only when locking the door and did not blink when unlock. I suppose this is the default setting.
However, I have coded the GM5 module together with some more things, including
QUIT_OPT_SCHAERF aktiv
QUIT_OPT_ENTSCH aktiv
But now the blinkers do not blink neither when I lock, nor when I unlock the car. I tried it twice, the other coding I did in the GM5 works absolutely fine, except this. It is totally the other way round.
I have attached my .MAN file for your to have a look.
Another question, as I have already started a thread: I cannot activate the DRLs as well, I tried everything as shown. Actually, for Europe, how should they look and what should I happen - they should switch on when I start the ignition, right? Because before I had no lights when I turned the lights switch in position 1, only in position 2. I now have dimmed lights in Position 1, but I do not think these are the DRLs, as I have to switch the lights button to position 1 first, they do not start automatically.
If you have any idea, I can try this tomorrow again.
Best,
Rangel
The .MAN file for the GM5 starts below:
WISCHERPOTI
aktiv
ANLAUFSTROMBEGRENZ_MEMO
aktiv
SCHEIBENABSENK_OHNE_EKS
aktiv
FH_NACH_TUERE_AUF
nicht_aktiv
E52_FUNKTIONEN
nicht_aktiv
FENSTERHEBER_VORNE
aktiv
DIFFERENZ_ANLAUF_BLOCK
wert_01
FH_FAHRERTUER_TIPP_AUF
aktiv
FH_BEIFAHRERTUER_TIPP_AUF
aktiv
FH_TUEREN_HINTEN_TIPP_AUF
aktiv
FH_ZTR_SCHALTER_TIPP_AUF
aktiv
FH_ZTR_SCHALTER_TIPP_ZU
aktiv
SCHEIBE_ABSENKZEIT
wert_01
ZEIT_TUER/SCHLIESSZEIT
wert_01
VERRIEGELN_AUT_AB_X_KM/H
aktiv
VERRIEGELN_AUT_NACH_2_MIN
aktiv
SOFT_ON/OFF
aktiv
IB_EIN_SCHLOSS_ENTRIEGELN
aktiv
IB_BEI_KL.R_AUS
aktiv_mit_kl.58
ABSCHALTUNG_VERBRAUCHER
aktiv
HECKKLAPPEN_LOGIK
geschlossen
KOMFORTSCHLIE_FB_OHNE_SHD
nicht_aktiv
EINGANG_2
nicht_aktiv
EINGANG_2_KONTAKT_GESCHL
nicht_aktiv
QUIT_AKUST_SCHAERF
aktiv
INNENLICHT_AN_MEHRFACH_ZV
aktiv
VERZUG_PANIK_MODUS_0.2_S
wert_01
VERRIEGELN_XKM/H_SENDER_1
aktiv
HKL_SPERREN_BEI_ZS
nicht_aktiv
VERRIEGELN_XKM/H_SENDER_2
aktiv
VERRIEGELN_XKM/H_SENDER_3
aktiv
VERRIEGELN_XKM/H_SENDER_4
aktiv
WISCHER_RUECK_GESCHW
wert_01
EKS_OFFEN/UNTERBRECHUNG
wert_01
EKS_GEDRUECKT/OFFEN
wert_01
CODIERUNG_ERFOLGT_1
codierung_erfolgt
VERRIEGELUNGSSCHWELLE
12_km/h
KOMFORTOEFFNEN_FB_O_FH_HI
nicht_aktiv
KOMFORTOEFFNEN_FB_O_SHD
nicht_aktiv
IB_SPERRE_BEI_FEHLER
aktiv
OHNE_INTERVALLBETRIEB
nicht_aktiv
INTERVALLZEIT_GESCHWABH
aktiv
KENNLINIENFELD2_AKTIV
nicht_aktiv
BLOCKIERSCHUTZ_AKT_XXS
16s
MIT_WISCHER_SERVICEPOS
nicht_aktiv
WISCHER_VOLLEND_KLR_AUS
nicht_aktiv
SENSOR_REGEN_N_STUFE2
nicht_aktiv
WISCHEN_ERST_XXS_WASCH
300ms
OHNE_WISCH_BEI_WASCH
nicht_aktiv
ANZAHL_NACHWISCHZYKLEN
3
ANZAHL_WASCHBET_ZUR_SRA
5
MIT_SRA_EIN_LENKSTOCK
nicht_aktiv
SRA_MIT_WASCH_WISCH_SW
nicht_aktiv
ANZAHL_SPRITZIMPULSE
2
DAUER_SPRITZIMPULSE
700ms
PAUSE_ZW_SPRITZIMPULSE
1300ms
MAUT_N_ABBRECH_N_TUER_AUF
nicht_aktiv
EKS_REVERSIERZEIT_ZUS
1000ms
FH_TIMEOUT
8s
KISI_N_DEAKT_IM_CRASH
nicht_aktiv
AUSSTELLFENSTER_ZEIT
plus_0s
EINSTIEG_FH_ZU_VER_SPERRE
aktiv
CENT_LOCK_MGL_VO_TUER_AUF
nicht_aktiv
HECKSCHEIBEN_LOGIK
geschlossen
N_VER_B_ERN_GESCHW_SCHWEL
nicht_aktiv
ANSTEUERZEIT_ZV_AGGREGATE
plus_0s
ENTR_HKL_MGL_WENN_VER
nicht_aktiv
ENTR_HS_MGL_WENN_VER
nicht_aktiv
SCHLIESSYSTEM
d_schloss
ENTRIEGELN_HKL
1x_tastendruck
POLLING_ZEIT_L_SCHLOSS
10ms
BETAET_DAUER_WIPPTASTE
kurz
NOTENTRIEGELN_HKL
aktiv
IB_EIN_BEI_HKK/HSK
nicht_aktiv
IB_EIN_16MIN_WENN_STANDLI
nicht_aktiv
IB_AUS_NACH_X_SEKUNDEN
20s
IB_EIN_N_KL_58G_MAX_1MIN
nicht_aktiv
VA1/VA2_AUS_NACH_X_MIN
16_min
VA1_SPERRE_BEI_FEHLER
nicht_aktiv
VA2_SPERRE_BEI_FEHLER
nicht_aktiv
VERL_ALARMZEI_WAEHR_ALARM
nicht_aktiv
HEULTON
nicht_aktiv
OFFENE_FENSTER
nicht_aktiv
VERZUG_ENTR_HECKKLAPPE
nicht_aktiv
E85_FUNKTIONEN
nicht_aktiv
E83_FUNKTIONEN
nicht_aktiv
OHNE_FERTIGUNGSMODE
nicht_aktiv
OHNE_TRANSPORTMODE
nicht_aktiv
OHNE_SERVICEMODE
nicht_aktiv
OHNE_POWERDOWNMODE
nicht_aktiv
BETRMODI_DEAKT_KL15_EIN
nicht_aktiv
SCHWELLE_OBEN
wert_01
SCHWELLE_UNTEN
wert_01
VERDECK_VORNE_E85
nicht_aktiv
CODIERUNG_ERFOLGT_2
codierung_erfolgt
MIT_LIN_SCHALTER
nicht_aktiv
MEMORY_POS_SPEICHERN
wert_01
MEMORYANFAHRGENAUIGKEIT
standard
MEMORY_POS_ANFAHREN
wert_01
ABKLAPPWERT_GM
wert_01
MEMORY_SP_ABKLAPPEN_GM
nicht_aktiv
DELAY_MOTOR_ZV_ER
wert_01
WISCHERINTERVALL
5_sec
ENTSICHERN_CENTERLOCK
aktiv
QUIT_AKUST_SCHAERF_KLAPPE
nicht_aktiv
QUIT_AKUST_ENTSCH
aktiv
ALARM_OPT_FERNLICHT
nicht_aktiv
PANIK_MODUS
nicht_aktiv
SCHEINWERFERREINIGUNG
nicht_aktiv
SENSOR_REGEN
nicht_aktiv
STANDRUECKSCHALTUNG
aktiv
HUB_VERZOEGERUNG_FH_VORN
0ms
OHNE_SCHEIBENABSENKUNG
aktiv
FUNKTIONTUERSCHLOSS
einstiegshilfe
FERNBEDIENUNG_1
nicht_aktiv
FERNBEDIENUNG_2
nicht_aktiv
FERNBEDIENUNG_3
nicht_aktiv
FERNBEDIENUNG_4
nicht_aktiv
FH_ABSCHALTKRITERIUM
ece
FUNKTION_CABRIO
nicht_aktiv
KOMFORTOEFFNUNG_FB
aktiv
FH_ABSENKEN_VERDECK_OEFF
nicht_aktiv
AUSSTELLFENSTER
nicht_aktiv
FENSTERHEBER_HINTEN
nicht_aktiv
EINKLEMMSCH_VORNE
aktiv
EINKLEMMSCH_HINTEN
nicht_aktiv
EINKLEMMSCH_REVERSIEREN
kurz
FH_FAHRERTUER_TIPP_ZU
aktiv
MAUT_NUR_BEI_KL15EIN
nicht_aktiv
FH_BEIFAHRERTUER_TIPP_ZU
aktiv
FH_TUEREN_HINTEN_TIPP_ZU
aktiv
FUNKTIONEN_TOURING
nicht_aktiv
HECKSCHEIBE_ENTR_SENDER_1
nicht_aktiv
HECKSCHEIBE_ENTR_SENDER_2
nicht_aktiv
HECKSCHEIBE_ENTR_SENDER_3
nicht_aktiv
HECKSCHEIBE_ENTR_SENDER_4
nicht_aktiv
HECKSCHEIBE_ENTRI_INNEN
nicht_aktiv
KOMFORTSCHLIE_FB_O_FH_HI
nicht_aktiv
DWA
nicht_aktiv
NEIGUNGSGEBER
nicht_aktiv
FUNK_INNENRAUMSCHUTZ
nicht_aktiv
QUITIMP_SICHERN/ENTSICHER
nicht_aktiv
SCHAERFEN/ENTSCHAERFEN
schloss_und_fernbedienung
ALARM_AKUSTISCH
intervallton
ALARM_AKUSTISCH_LANG
nicht_aktiv
ALARM_OPT_WARNBLINKER
nicht_aktiv
FH_ANHEBEN_TRANSPORT
nicht_aktiv
MIT_OPT_ALARM
nicht_aktiv
FH_SPEICHERN_TRANSPORT
nicht_aktiv
ALARM_OPT_ABBLENDLICHT
nicht_aktiv
QUIT_OPT_SCHAERF
aktiv
QUIT_OPT_SCHAERF_KLAPPE
aktiv
QUIT_OPT_ENTSCH
aktiv
FUNKINNENRAUMSCHUTZ_HI
nicht_aktiv
DWA_HANDSCHUHFACHKONTAKT
nicht_aktiv
OHNE_FERNBEDIENUNG_0
nicht_aktiv
KOMFORTSCHLIESSUNG_FB
aktiv
IR_FERNBEDIENUNG
nicht_aktiv
TAKTUNG_IB
nicht_aktiv
TAKTUNG_VA1
nicht_aktiv
FH_INIT_TRANSPORTMODE
nicht_aktiv
TAB_WIEDERHOLSPERRE_ASF_2
nicht_aktiv
TAB_ANSTEURN_ASF_2
nicht_aktiv
KOMFOEFFNEN_SPERRE_KEY_IN
nicht_aktiv
TUER_HINTEN
aktiv
RECHTSLENKER
nicht_aktiv
SITZMEMORY_VERBAUT_GM
nicht_aktiv
MIT_LIN
nicht_aktiv
SPIEGELABKLAPPEN_GM
nicht_aktiv
V_VAR_SPERRE_BEIKLAPP_GM
klemme_r
SPIEGELHEIZUNG_VERBAUT_GM
nicht_aktiv
BEIKLAPP_B_KOMFORTSCHL_GM
aktiv
BEIKLAPPEN_GM
nicht_aktiv
BEDIENSTELLE_BFT
nicht_aktiv
CENT_LOCK_N_MGL_VERD_AUF
nicht_aktiv
DWA_HECKKLAPPENKONTAKT
nicht_aktiv
DWA_HECKSCHEIBENKONTAKT
nicht_aktiv
SCHEIBENABSENK_REVERS
nicht_aktiv
SPRITZDUESEN_HZG
nicht_aktiv
TRA_SCHEIBENABSENKUNG
aktiv
TRA_ER_HECKKLAPPE
aktiv
TRA_FH_BF_HINTEN
aktiv
TRA_FH_BF_VORNE
aktiv
TRA_FH_FA_HINTEN
aktiv
TRA_FRONTSCH_REINIGUNG
aktiv
TRA_SRA_1
aktiv
KOMFORTOEFFNEN_CABRIO
nicht_aktiv
SPIEGELMEMORY_GM
nicht_aktiv
FE_SCHEIBENWISCHER
aktiv
REMOTE_UNLOCK
nicht_aktiv
VERZ_EINSTIEGSHILFE
4sec
FE_FRONTSCH_REINIGUNG
aktiv
FE_SRA
aktiv
FH_SPERREN_B_VERDECKLAUF
standard
FH_ZU_N_VERDECK_ZU_O_EKS
nicht_aktiv
VERDECKINFO_EKS
nicht_aktiv
IB_SUCH_MIT_VFB
nicht_aktiv
MIT_VFB
nicht_aktiv
TAKTUNG_VFB
nicht_aktiv
VFB_SPERRE_BEI_FEHLER
nicht_aktiv
#6 · (Edited)
For the blinking when locking/ unlocking have you tried with P.A Soft? I found it easier with that one (you can also try with NCSdummy).
For the DRL's if your car has the US spec when you turn the engine on the high beams will turn on but on a lower voltage so they'll be dimmed. If your car is an Euro spec look at your headlight and you'll see a little (I guess it's 5W) lamp, that's the city light/ drl.
#10 ·
I cannot do it. I've tried several combinations and it doesn't work. The car never blinks.
DWA (alarm)
Tried with aktiv and not aktiv
My GM5.C05 does not have these options:
DWA_NOTENTSCHAERFEN
aktiv
DWA_QUITTIERUNG
aktiv
ZV_ENTR_SCHL_BEI_DWA_AKT
aktiv
This is active:
QUITT_BLK_SICHERN VISUAL LOCK WITHOUT ANTI-THEFT ALARM SYSTEM
nicht_aktiv not active
aktiv active (turn signals blink when lock the vehicle)
Any idea why it is not working?
#12 ·
I know this is a somewhat stale thread but my 2001 330ci (09.2001) was also not showing visual locking indication until I enabled non existent DWA. Audible indication doesn't work, but maybe that's because there is no alarm??
Status
You have insufficient privileges to reply here.
