1 - 9 of 9 Posts
Hello everyone I have a 2005 325i sedan m54 engine that is throwing bank one and 2 lean codes I have a new fuel pump new fuel filter new disa new MAF sensor new spark plugs and new post cat o2 sensors and no vacuum leaks ( I have smoke tested it 100 times) it has a rough idle after I’ve been driving for 5 or more minutes I have a janky cold air intake that is probably a hot air intake but I can’t seem to get the codes to go away any help is appreciated
Premium Member
2002 BMW 540Ti, 2004 BMW 330i ZHP, 2001 325Ci
My MAF had a sticker that stated 'Made in China" and was the cause of my lean codes... Replaced it with a used BMW MAF.
I needed a spare OEM MAF sensor an ordered a used from LKQ, they seem to be a big used parts outlet, was happy with steering rack from them an hoping it will be a seimans with 55k miles
Premium Member
2000 E46 323i, 3.0L, 2.8L and 2.0L Z3's
Since you have smoke tested and fixed he vacuum leaks, set up OBD Fusion and run the 3 standard logs. Post links to the CVS log file here and we will look a them. Tey save us from asking a 1,000 questions and frustrating you from having to answer them. OBD Fusion
I see that you are new here. Welcome to the forum. Lets get you set up:
  • Go to www.RealOEM.com and put the last 7 digits of your VIN into the search tool. Bookmark the results page and then you can browse for parts for your car.
  • Find wiring diagrams here: BMW WDS Online
  • The "Important Links" page has lots of really useful information: IMPORTANT LINKS
Premium Member
Ok, lets go the 1,000 question route.
Here are the first 3 questions:
  • What are the 4 fuel trims at hot idle with the engine running?
  • What are the 4 fuel trims at a steady 100 kmph (60 mph) cruise with cruise control on?
  • What is the coolant temp at steady cruise. Tip, use the hidden menus in the dash to get the actual coolant temp.
1 - 9 of 9 Posts
