1 - 14 of 14 Posts
Just got home and got a flat...large hole in tire. Currently using the M mobility system to put air in.. Don't want to let it sit on rim..
Thoughts on what to do? Don't have a jack that will fit (maybe a neighbor will have), and everywhere is closed...
Will it damage the wheel to let it sit overnight on a totally flat tire??
Call BMW roadside assistance- They should be able to get that sucker to the local dealer (on a flatbed! Don't let 'em tow it- just in case they try for some loony reason), and put it down on something that will prop up the frame / suspension on the axel with the flat-
Discussion Starter · #3 ·
So will it damage the wheel to let it sit overnight?
I'm not sure if I take it to dealer if there is anything to prop it up with under the frame...
Bimmerless
There is a can of fix a flat. how big is the hole do you think? is it leaking to the point where you can hear it? use the tire seal if you think it will hold, and pump it up. But im thinking your tire is done for, high performance tires shouldnt be patched, if you ask me. but that is just a paranoia i have.
Alpha Male
there should be a removable jack point next to your M mobility kit in the trunk.
Find a local fanatics and borrow his jack and place a block unter the car to support it.
Also the tire is ruined already so the tire should protect the rim from damage if you don't drive on it.
Don't use fix-a-flat! It makes a mess on the inside of the rim that most mechanics don't clean when replacing a tire. Also fix-a-flat is flammable, so tell the mechanic before hand if it has fix-a-flat in it, wouldn't want that stuff to ignite accidentially. Just letting it sit on the rim should be OK, unless you have some lightweight aluminum rims, just don't try driving on it. Even though the tire is probably already ruined, you would not want the tire to come off the rim while driving it and risk scarring up your rims.
Yeah- Don't use fix-a-flat it does mess up the rims, and even if the hole is reparable (though it sounds like your is not) it messes up the tires.
If you do have a jack in your kit- get the car high enough to at least get someting under the axel- to help support the weight-
Your rim should be fine overnight- but it is designed not to have a large weight at one point (like resting on the bare rim)- So like Clem said the tire will protect it a bit- But personally I'd find a way to ease the weight on it a bit; even if you fill up the tire as much as possible with your air system, and jam something under the axel- like 2x4's on their side- so when the tire deflates- some of the weight rests on the wood under the axel-
Good luck Bro!
You guys are going to make M3Fella go crazy with jacks and pieces of wood.
Am I the only one that has seen a car sit on a flat for months or years and the rim is still fine? It's a rim, fer chrissakes - one of the strongest parts of a car!
It can sit on the flat tire. If your rim has a flat spot in the morning, it means the earth's gravitational pull mysteriously increased 1000X overnight.
- Rob
Anyone ever tried inhaling freon? I knew this guy who would go around to people's AC units outside their house and valve off some freon in a plastic bag. He would inhale it claiming he got high from it. What a moron!!:rolleyes:
1 - 14 of 14 Posts
