wow the reslut came up nicely!I rewired a few of the LEDs so they fit better into their segments and also replaced them with some 450 mcd strong ones since the old ones with 210 mcd weren’t visible during sunshine. They are still not too bright for night rides
I have m3 eeprom I've taken out from my original M3 cluster. Now I'm wondering how to change the Fuel Economy Gauge to Oil Temp just like M3So yeah. You need to move leds to fit it but maybe someone have m3 eeprom to play with it?
wow nice! keep us updated!So im trying to do some update on my cluster. From what i found, procesor in bosch cluster can be different and thats why it cant show oil temp. So i've got idea that i can add my oil temp gauge, my oil temp sender and try to fit it to oryginal cluster. I couple of days i will try to test it. View attachment 962699
great job!!!Yeah this method working fine!
View attachment 963228 View attachment 963225
Hi guys . please tell me what was in this video since it was deleted? what needs to be transferred from the m3 dump so that the LEDs are activated? What to transfer from a regular dump to an m3 dump, in order to make a speedometer 240 and a tachometer 7, I have a concept, but I would like to transfer only the parameter responsible for the LEDs to the m 3 dump, so that the dashboard remains ci08 and not ci24 . thank you in advance .Hi, I think regarding your issue there's must be an answer from this video
its on duration 15:56.
I would also like to edit exactly the dump of the dashboard, in order to be able to use it with an automatic transmissionHi guys . please tell me what was in this video since it was deleted? what needs to be transferred from the m3 dump so that the LEDs are activated? What to transfer from a regular dump to an m3 dump, in order to make a speedometer 240 and a tachometer 7, I have a concept, but I would like to transfer only the parameter responsible for the LEDs to the m 3 dump, so that the dashboard remains ci08 and not ci24 . thank you in advance .
guys help please. I can’t write in a personal to those who have earned it with a non-m dump. probably not enough posts. please unsubscribe what you need to edit in the hex code. the video is no longer available. thanks. I want to use an automatic transmission, but with the m3 dump this is not possible. and the oil level does not work.Yeah it works, with scanner everything is easy![]()
Gesendet von iPhone mit Tapatalk
