is the fuel consumption gauge has changed to oil temp?Yeah it works, with scanner everything is easy![]()
Gesendet von iPhone mit Tapatalk
glad to see its working. I've ordered the LED's and chips from digikey, hopefully it'll arrive soon and try this mod by myself.Thank you so so much for the help! It really worked.
(don't forget to save the changes before rewriting the EEPROM😅)
Now I only have to figure out a way to cut the difusor behind the dashboard...
thanks for the tipJust take your time
I used a small soldering tip and small tweezers. Was a bit fiddly but worked on the first try. Just make sure, you dont have any shorts
that's good! keep us updated.Yeah you definitely don’t want to do it like I did. I will order a fresh one from eBay
I have M3 cluster on my car, but its the original m3 one, it act the same like yours. When the engine is cold like I've parked the car for a night then in the morning I turned the car up the LED's is fully turn on like the picture below, but when the engine is on fully working temperature the LED's would go down to 7000 RPM. So I think yours is completely normal.while letting the car warm up, I stumbled apon some strange behaviour:
The LEDs turn off in the order 1 to 5, but the circled LED in the top right corner stays on... Is that supposed to happen?
View attachment 951830 View attachment 951828
Google translate says it means: speedometer disc."tachoscheibe" I don't know that in english
well, apparently some of us managed to fix the issueDid you managed to fix the Issue with the LEDs ?
I will be interested in doing this in the future, so looking for any possible issues hahawell, apparently some of us managed to fix the issue![]()
Maybe u can read out an eeprom from your cluster and upload it here so we can take out a speedo and tacho curve and adjust normal cluster to corectly rev to 9k rpm?glad to see its working. I've ordered the LED's and chips from digikey, hopefully it'll arrive soon and try this mod by myself.
is it hard to do the "soldering" part?
one question though, where did you bought your cluster overlay?While operating the regular cluster with the LEDs we notice that they are only properly placed inside the m3 cluster since the segmentation of the rpm is slightly different.
so to do it like 99 percent correctly you would need to solder some wires and then move the leds to the proper position.
So yeah. You need to move leds to fit it but maybe someone have m3 eeprom to play with it?Well the standard cluster fits me more
