I just swapped out the Hk subs with Kicker 6x9's.
The bass output seems on the low side. If I increase the bass setting on the head unit it helps a little but it also increases the bass in the doors and that causes more rattle and distortion.
The Hk subs are 2 ohm and the Kicker's are 4 ohm.
Do I need to wire the Kickers together in some way to get 2 ohm? If so how?
