1 - 20 of 56 Posts
Just did the Harman Kardon fix!!!
Hey guys,
I have dealt with this rattle for about 2 and half months now. Finally I got fed up with it today and went did the DIY fix. I stuffed a bunch of towels in the two holes and voila! My stereo sounds 100x better now that I have done this. If you haven't, its so easy and it really helps a ton. I just have one question to ones that have taken the harmon kardon out, or done the fix, I broke both the white tabs that are beside the front screws. I think you can get them out with a flat head but I ended up breaking them. Does anybody know if it will be okay without them. I got the 4 remaining bolts really tight?
Thanks,
Chad
Tinfoilhatatarian
ChadH said:
Hey guys,
Thanks,
Chad
please eloborate
Tinfoilhatatarian
ChadH said:
On which part? The fix itself or the clips that I broke?
both.. curious to see if I should do this fix as well and also which clips so i dont break the same ones thanks!
You ain't fresh AZIMIZ!!!!!
It's funny, that's the ONLY fix! I did it the 1st week I got my car :p
i have some rattles in my car. and would love to get rid of this one ,but fisrt what are you talking about? where did you stuff towels?
I've done it too - bunch of old shirts for me - can actually boost the base once you do it.... then you have to deal with the door rattle!!!! **** harmon option 600 bucks will buy you a much better set up at circuit city/best buy
idoc330ci said:
Yeah...that H.K. rattle drives me crazy. I'm gonna try the nut and bolt diy to fix the rattle :thumbup:
I did this one and it worked like a charm... I didn't like the idea of towles stuffed in the back of my car. This is the best fix I have found http://www.cardomain.com/memberpage/262483/2
I also added a rubber stopper to the end of the bolt to push up on the rear deck... NO MORE RATTLE BABY!!! :woot:
Discussion Starter · #12 ·
Here is a quick step by step fellows.
1) Open your trunk and locate the harmam kardon subs under the rear deck. It is really hard to miss as it is a big black block. There are 4 bolts total on this, 2 on the front and 2 on the sides.
2) Remove all the bolts and you will notice 2 white plastic clips still hold it in. I didnt know how to remove this. In turn, I ended up wiggling these damn things until they broke. Once they break or you get them out, the sub box will fall.
3) There are 2 holes that you will see once the black box falls. Those are the 2 holes that you shove shirts, towels, socks or anything you can find. Now, this is important. Stuff this full of stuff.
4) Once that is done, re-install the sub box. Install the 4 bolts and 2 clips(if you didnt break them). Now, the rattle should be fixed.
On a side note, some say you need to unplug the sub box. I didnt, I was really careful and just let it hang. Its up to you.
-Chad
Read Only
-Chad
Thanks! I'm sooo going to try this when I get home! :thumbup:
Discussion Starter · #16 ·
I would have done the exact same thing. But, the dealership is about an hour away from me, so I figured I would rather do this in 20 minutes than drive an hour and let me them fix it.
I'm hot 'cause I'm fly
thats my fix! i did that a couple years ago. It works great and i have never experienced the rattle ever again. I havent had any problems w/ the old rags in there either. The bass sounds great now too.
As for the tabs, yeah, they are a bi tch to get out, you just have to pull real hard. IF you break them, it wont really matter, the 4 bolts holding it in should be fine.
-Mark
so what did u do about the door rattle?
i have the hk sound system but when i open the trunk i dont see a black box. did the previous owner take it out? any one have any pics of it?
1 - 20 of 56 Posts
