I am at wits end...
Got ISTA+ and ISTA/P working on a new Windows 10 laptop.
Using a eBay K+DCAN INPA compatible cable.
ISTA/P is version 3.67.0.000
Can download the build etc from the car, but cannot program as I get no voltage at terminal 15 or terminal 30.
I have done a lot of research (not here though) and have ensured battery is totally charged above 14V and also connected a 13.8V voltage regulator that can supply 20A.
I have seen some posts suggesting it may be the cable. I have tried the cable switch in both positions. Only one position works to download the build sheet.
No terminal 15 or 30 voltage though.
Any suggestions or help is greatly appreciated.
I now suspect the cable...
I know the test of voltage can be removed, but want to try and get it working correctly for car-running-again purposes.
I there is a fix for voltage checking, can you point me in the right direction?
Garry
Garry
