Hello everyone,
I own an E46 330XI that I ended up replacing the CCV about a month and a half ago. After I removed everything, I washed the engine bay before I put everything back on. After I installed everything back on, the car wouldnt start. My wife had a baby so I couldnt work on it for over a month and the battery died. I jump started the car yesterday for the car to start and it idled VERY rough so I shut it off, come to find out the coils were drenched in water. I pulled them out, dried them and replaced the spark plugs since they were in pretty bad condition, however the car still runs super crappy and it starts only half the time I jump it.
These are the codes that I am getting:
36-Main relay
100-Control unit failure
37-Switching delay main relay
68-tank ventilation valve
53-LLFS opening coil Elec.
27-LLFS Closing coil Elec.
32-secondary air valve
140-output stage failure dmtl pump
126-output stage failure dmtl valve
124-Variable jet system
can anyone assist me on where should I look to properly diagnose or to better pin point the issue? The battery needs replacing for starters but, where to next?
Thanks in advance
36-Main relay
Thanks in advance
