1 - 4 of 4 Posts
forgestar f14
18x12+35 rear 305 mt street II
18x9+25 front 255
first question, are these wheels ****? second question, can i fit w/o rolling my fenders? suspension is stock
Probably not the rears. 11's are the widest HPF could go and I might still have to roll my fenders a tiny bit.
12 inch rim is to wide for a 35 offset, the widest Id go with a 35 offset is 11, with that offset and that rim you will very likely rub the trailing arm. Derek, with the 11 inch rim it actually makes the 305 wider. if you run a smaller rim it would make the tire taller and not as wide so you wouldnt need to roll the fenders
You can squeeze an 19x11 +33
I helped a few people on M3Forum do it back then. You'll need to run a stretched tire, camber, roll, a spacer and all that mess hahah.
1 - 4 of 4 Posts
