1 - 20 of 20 Posts
2002 330 Ci
For those that know, I'm basically building a new e46 330ci vert. As I disassemble and clean bits I find questionable bits.
So, the lady who had this car bottomed it out quite a bit and there's some indentations on the sub frame.
It came off really easy as it should and isn't warped. Here's the pics.
924948
924949
924950
924951
OEM ///PLUS
2003 M3 6MT Slicktop
i don’t see anything that appear to show it being bad from what can be viewed in photo.
thing with that reinforcement plate is it’s two panels connected. the one that gets any dings isn’t the one that is directly touching the chassis reinforcing it.
the plastic engine undershield is the one that gets beat the most. it doesn’t do anything for the structure so no biggie.
Premium Member
That's the reinforcement plate-
and it looks better than mine.
The subframe's the cradle that supports the engine and attaches to the front control arms.
t
would use that
2002 330 Ci
Discussion Starter · #4 ·
t
would use that
Ooops.... that's right. Reinforcement plate. I don't know why I thought subframe.
Thanks for the info.
Yes. You can tell it's done a few belly flops. If you know a tig welder you could have it touched up along the edges. Put your mind at ease. It doesn't look like it was used as a jacking point at any time.
//Binary is in my DNA
2002 BMW 325i
Looks good to me.
Get the oil drain cover plate while you're at it. 51-61-7-199-687.
Thanks for posting the part number Spanner, always been wanting to get that part. Ordered on FCP for $9.95.
OEM ///PLUS
for the oil door cover I also zip tied mine so it couldn’t be lost. if it ever got dislodged it would still be somewhat attached. same thing happens with the M3 ones. they mysteriously disappear even when all fasteners are used.
Super Moderator
'02 330i 5-Speed
Hmm...low-pressure area under the car sucks it off...?
Where do you zip-tie it? The slots at the back?
OEM ///PLUS
yeah I don’t know if it’s flexes and comes off or water hits it hard enough? people use to say they thought their shops forgot to reinstall. I do my own oil and replace and have lost them.
Yep, drill two tiny holes and use zip ties like a hinge.
Super Moderator
'02 330i 5-Speed
Super Moderator
'02 330i 5-Speed
^Also valid options. I just ordered a whole bunch of various body clips off eBay a while back and I knew it was a source. Wouldn't touch eBay otherwise if were a matter of something more critical to the car's function/appearance.
1 - 20 of 20 Posts
