When it is warm out but raining the car fogs up. Defog blows warm air even at cold setting so car get too uncomfortable until fog clears up and you set the blower back to vent. May be that's the way they are for cars with cold weather package only? Obviously some people on this board have no problem with their car this way. Solutions anyone?BimmerJustin said:Its the winshield defroster. Why would you want cool air coming from there?
Thanks. That works. I can manually close the vents so the air on the defog is stronger too.Keeferno said:Yes, it is designed to blow hot air when you hit the front defogger button. If you don't like it just select the top vent manually (which is the same one the defogger uses) crank up the fan and it will blow at whatever temp you currently have it set.
