a UUC ssk EVO3 for a xi from inside the car only. Removing the circle clip I think may be possible from the inside with a long flat head screwdriver and holding onto it with angled long needle nose. Holding onto the selector rod with bail wire, so I can pull it back onto the shift lever. And using angled snap ring pliers and long angled needle nose to put the circle clip back onto the bottom of the shift lever. What do you think... the xi kit only has the lever, and ERK, which I should be able to screw the six screws from the top. It doesn't have a new weighted selector rod to install...am I nuts to try this install from the inside only?? :dunno:
