Listen to the heater valve with your stethoscope. The rubber support on mine's getting stiff,
and I can hear it cycling when I'm sitting at a light. If I turn off the heat (fan to 0) then
it stops, and if I change temperature, I can get the duty cycle to change (rate and rhythm of thump).
To find your heater valve, start at www.realoem.com and look up the diagrams. Then lift the hood
and see if you can find it, down below and in front of the brake booster. It's kinda hard to see
at first, but if you follow the coolant hoses, there it'll be.
fwiw.
t
fwiw.
t
